![]() | Home > Puma (Tdci) > Idling surges |
Landyrover Member Since: 04 Jul 2011 Location: Northampton Posts: 33 ![]() ![]() ![]() |
Could this be an injector problem?? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson)
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 ![]() ![]() ![]() |
Mine only does it cold, starts ok and idles but when rpm run between 800 and 1200 feels almost like half a cyl missing. Also smoke. When it warms all good. Cold here at the moment (mid winter) 8 dec cel. In on Thursday to find out why. Will post if they fix It.
Allan |
jasonshum Member Since: 10 Jun 2011 Location: Hong Kong Posts: 13 ![]() ![]() |
this..??
EGR related also......
Try to disconect the EGR connector Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
^^^^^^^^ Most problably. My EGR was properly shut down and no more idle issues. Puma 110" SW
Mine does the miss like thing only when cold and when throttle used very lighyly at very low rpm. EGR was replaced last month, not that that means anything.
Allan |
Where is this please? Cheers "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
That's it, but settled after 10-15 seconds. Did you fix this? "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
rev it Member Since: 25 Jul 2011 Location: Kent Posts: 6 ![]() ![]() ![]() |
Hello, About two weeks ago, I had the fuel metering valve fitted. So far I have had no odd surging (fingers crossed) since.
Good news!
Took mine in today to sort. Will report when they return it. I also have a caster issue, slight pull left that i want fixed, doesn't annoy around the city but on long trips its a pain.
Allan |
Not Yan~~Too Bad~~~ |
fuel metering valve fitted?Change This is ok..?h |
Garage diagnosed sticking EGR valve. No fault codes generated but they say noise made when it goes through the self-cleaning routine when the engine is turned off is excessive.
Nick "You know, Marge, mud is nothing more than wet dirt!" (Homer Simpson) |
