Home > Puma (Tdci) > Bonnet stolen again.
Page 2 of 9 <123456789>
bob neville
Interesting Stu.
I wonder if they will fit a Defenders bonnet ?
I feel a phone call coming on Thumbs Up
Bob
Post #87813 5th Sep 2011 9:08pm
mick
We need to put RLD to the task of coming up with some different hinges.
Post #87814 5th Sep 2011 9:17pm
BigMike
By the time that happens the last defender will be dust in the wind mate Laughing
Post #87819 5th Sep 2011 9:53pm
BigMike
Small Clanger wrote:
www.steinel.co.uk do a battery powered PIR sensor that can send a signal to one of their wire-free doorbell chimes. Put the sensor overlooking the Defender and plug the chime in next to your bed. That way, when someone triggers the sensor and the thing chimes at 3a.m. your skellington will be out of the door and open for business before you and your jim-jams are out of bed. Beleive me, I know.
Thats what I have. Trouble is it kept going off for no reason and you're right, you absolutely fly up and out. In the end i got a sleeve which narrows the beam, then pointed it at a certain area on the vehicle and it works just fine. Mine was a hundred quid from memory
Post #87820 5th Sep 2011 9:56pm
funrover
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
We're working on some serious security products for the Defender, but why not try shearing / security fixings (i.e. bolts that shear at a set torque limit) and need to be drilled out. How often do you need to remove the bonnet? This might be a solution. Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here:
Post #87877 6th Sep 2011 11:58am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Mount a spring gun pointing to the bonnet ... Never forget: cars have owner, Landrover have field service personnel.
Post #87880 6th Sep 2011 12:12pm
The bonnets aren't held on with bolts. If you lift them up high enough they just lift out of the hinges. Darren
Post #87886 6th Sep 2011 12:43pm
mse
Worrying isnt it Whistle Mike
Post #87911 6th Sep 2011 3:32pm
Zagato
Honker wrote:
Crappy news. I've seen these used on a few cars now, not cheap but might be of interest.
http://www.driftworks.com/shop/car-parts/b...cking.html
Stu
These look interesting if they fit - you only need one so could go halves with someone. They could still get the bonnet off if determined but not many people would want to buy it with this stuck into it with a hole made. I wonder how it would look though Shocked
Maybe K9F could trial it Whistle
Post #87912 6th Sep 2011 3:36pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Stevie is a bit happier at the moment, he has a brand new RRS to bomb around in, im just finding him a baseball cap and some addidas gear from the boy so he looks the part.
Post #87914 6th Sep 2011 3:49pm
jonny1966
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Stu
they look the buizz, you are all getting me worried so might get a set
Post #87920 6th Sep 2011 6:00pm
Zagato
Stu
they look the buzz, you are all getting me worried so might get a set
Excellent Jonny, let us know how you get on and don't pinch my bonnet if it all goes tits up Shocked
Post #87925 6th Sep 2011 6:52pm
bob neville
What we need is a .....
Thumbs Up
Bob
Post #87930 6th Sep 2011 7:08pm
K9F
Rolling with laughter I will if you will, I'll go halves with you Zag.....
No need really.... I am relying on two things....
1. I've drilled 28 holes in mine and have Chequerplate with a nice little transponder embedded in the sealant underneath.
2. Being a sparky and for a few quid you could theoretically set yourself up with an autonamous rechargable battery pack, a siiren and a plunger activated microswitch which will operate irrespective if the alarm is bypassed or the battery supply is cut. With an undervoltage relay it will go off when and if the battery supply is chopped before the bonnet is even lifted! All available from RS.....Apparently.... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #87931 6th Sep 2011 7:20pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Thumbs Up
Bob
Bob, unless thats the ninja version I can't see it scaring anyone off
Stu
Post #87938 6th Sep 2011 8:12pm
