![]() | Home > Puma (Tdci) > Bonnet stolen again. |
Interesting Stu.
I wonder if they will fit a Defenders bonnet ? I feel a phone call coming on ![]() Bob |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
We need to put RLD to the task of coming up with some different hinges.
Thats what I have. Trouble is it kept going off for no reason and you're right, you absolutely fly up and out. In the end i got a sleeve which narrows the beam, then pointed it at a certain area on the vehicle and it works just fine. Mine was a hundred quid from memory |
funrover Member Since: 12 Dec 2010 Location: Yorkshire Posts: 130 ![]() ![]() ![]() |
We're working on some serious security products for the Defender, but why not try shearing / security fixings (i.e. bolts that shear at a set torque limit) and need to be drilled out. How often do you need to remove the bonnet? This might be a solution. Editor of FunRover - One blog. Read it!
Land Rover rebuild video series here: |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Mount a spring gun pointing to the bonnet ... Never forget: cars have owner, Landrover have field service personnel.
The bonnets aren't held on with bolts. If you lift them up high enough they just lift out of the hinges. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
Worrying isnt it ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
These look interesting if they fit - you only need one so could go halves with someone. They could still get the bonnet off if determined but not many people would want to buy it with this stuck into it with a hole made. I wonder how it would look though ![]() Maybe K9F could trial it ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
Stevie is a bit happier at the moment, he has a brand new RRS to bomb around in, im just finding him a baseball cap and some addidas gear from the boy so he looks the part.
jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87 ![]() ![]() ![]() |
they look the buizz, you are all getting me worried so might get a set |
Excellent Jonny, let us know how you get on and don't pinch my bonnet if it all goes tits up ![]() |
What we need is a .....
![]() ![]() Bob |
![]() No need really.... I am relying on two things.... 1. I've drilled 28 holes in mine and have Chequerplate with a nice little transponder embedded in the sealant underneath. 2. Being a sparky and for a few quid you could theoretically set yourself up with an autonamous rechargable battery pack, a siiren and a plunger activated microswitch which will operate irrespective if the alarm is bypassed or the battery supply is cut. With an undervoltage relay it will go off when and if the battery supply is chopped before the bonnet is even lifted! All available from RS.....Apparently.... ![]() Treat every day as if it is your last....one day you will be right!! |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Bob, unless thats the ninja version I can't see it scaring anyone off Stu |
