Home > Maintenance & Modifications > Puma spot light switch wiring.
Page 2 of 2 <12
jamesb123
Wiring Harness
I have recently bought two LED PERF spotlight for the front bumper of my 110, would anyone have any recommendation for a wiring harness kit (with switch) that will reach the battery under the seat?
I tried to order the Lazer two lamp harness from Devon 4x4 but they arena longer importing.
Thanks.
Post #878561 15th Jan 2021 9:00am
Bluest
I think Landreiziger do one but they changed the layout of their online shop and I can’t find anything on there any more. 2007 110 TDCi Station Wagon XS
Post #878564 15th Jan 2021 9:06am
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Re: Wiring Harness
Thanks.
I got a couple of these from Amazon , they might need extending but you have all you need Thumbs Up as I’m a most not a sparky there perfect for me Thumbs Up
Post #878569 15th Jan 2021 10:15am
jamesb123
Thats great, thanks for the help.
Post #878669 15th Jan 2021 6:53pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
How do I change this wiring diagram If I don't connect 86 to a high beam switch as I'm using this for a rear work light.
Bluest wrote:
My genuine style (made in Taiwan) switch arrived today. Appears decent quality. I've found this wiring diagram...
Any comments before I go ahead? It would be handy if I could get the correct female connector block to go into the switch. The pins are pretty tiny and might look a bit of a mess and be easily bent if I use little spade connectors or something. Is it available?
Post #901126 3rd May 2021 6:48am
Connect 86 to 12v, either permanent or ignition live, depending on how you'd like the work lamp to work. Darren
Post #901128 3rd May 2021 7:16am
Page 2 of 2 <12
