![]() | Home > Maintenance & Modifications > Front diff failure... |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
if your keeping it I would suggest a diff upgrade DEFENDER 90 TDCI XS,
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747 ![]() ![]() ![]() |
Looks like cow
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 ![]() ![]() ![]() |
suggests axle/dif oil not done as scheduled
Seal-front driveshaft, is letting one shot from the CV to mix with the EP90 diff oil
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
It’s amazing how long they will go with shocking care 1951 80" S1 2.0
Its not ideal when the oil hitting the pan sounds like a heafty cow pat hitting the barn floor.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
This Rgds. Chris |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
Its a whole lot thicker than that. Id sat a combo of seal failure and "extended" service interval ![]() |
Mine was similar (front) smelt awful as well!.
![]() Chris |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Coor that needed doing! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 860 ![]() ![]() ![]() |
Has the wobble gone now it has fresh oil or new diff?
Wobble is still there. Had fresh oil to try and clean out some of that gloop before the new diff goes in
Just need to find time to fit it ![]() |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
How are the panhard bushes?
Mine developed a terrifying wobble (and general lack of steering ability) when the panhard bushes finally fell apart. The diff oil looks similar to what came out of mine when I first bought it! Still goes though... |
So here we are, only 7 months later, it finally made it onto the ramp
![]() Front axle stripped down to find this... ![]() Click image to enlarge New diff, new swivels, new discs and pads, new steering damper, stainless caliper pistons, and probably more in the box I've forgotten about ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
