Home > Maintenance & Modifications > Front diff failure...
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Bought this, knowing it had a vibration when driving
From cold, it was fine
After a few miles, developed a steering wobble around 50mph
Another few miles and it got quite bad
After about 10 miles into a journey, it would then wobble down to 30mph...
Already had radius arm bushes, swivel pins replaced, brakes and hub bearings checked, new steering damper, nothing cured it
So stuck it on the ramp on Friday before leaving work. Noticed a little oil leak from the front diff, so decided to check the oil level. We greeted with something "not oil" Laughing
Juat as well a new diff isn't too expensive. And the swivel housings could do with being replaced anyway. And front discs aren't great Rolling with laughter
Post #877364 9th Jan 2021 11:42pm
LR90XS2011
if your keeping it I would suggest a diff upgrade DEFENDER 90 TDCI XS,
Post #877382 10th Jan 2021 7:01am
Co1
Looks like cow Censored !!
Post #877388 10th Jan 2021 8:50am
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
suggests axle/dif oil not done as scheduled Rolling with laughter
Post #877393 10th Jan 2021 9:10am
dorsetsmith
Seal-front driveshaft, is letting one shot from the CV to mix with the EP90 diff oil
Post #877394 10th Jan 2021 9:25am
familymad
It’s amazing how long they will go with shocking care 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #877397 10th Jan 2021 9:36am
kenzle8a
Its not ideal when the oil hitting the pan sounds like a heafty cow pat hitting the barn floor.
Post #877399 10th Jan 2021 9:48am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
This Rgds.
Chris
Post #877422 10th Jan 2021 11:23am
Disco_Mikey
Its a whole lot thicker than that. Id sat a combo of seal failure and "extended" service interval Laughing
Post #877496 10th Jan 2021 3:58pm
Pacha
Mine was similar (front) smelt awful as well!. Laughing Rgds.
Chris
Post #877511 10th Jan 2021 4:47pm
shaggydog
Coor that needed doing! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #877515 10th Jan 2021 4:50pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Has the wobble gone now it has fresh oil or new diff?
Post #877660 11th Jan 2021 10:10am
Disco_Mikey
Wobble is still there. Had fresh oil to try and clean out some of that gloop before the new diff goes in
Just need to find time to fit it Laughing
Post #878473 14th Jan 2021 4:30pm
miker
How are the panhard bushes?
Mine developed a terrifying wobble (and general lack of steering ability) when the panhard bushes finally fell apart.
The diff oil looks similar to what came out of mine when I first bought it! Still goes though...
Post #878484 14th Jan 2021 5:32pm
Disco_Mikey
So here we are, only 7 months later, it finally made it onto the ramp Laughing
Front axle stripped down to find this...
New diff, new swivels, new discs and pads, new steering damper, stainless caliper pistons, and probably more in the box I've forgotten about Embarassed Laughing
Post #916796 13th Aug 2021 7:52pm
