![]() | Home > General & Technical (L663) > 2 stage unlocking .... |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1131 ![]() ![]() |
Anyone else having a issue with it? Mine refuses to unlock anything but the drivers door when. 2 stage unlock is configured.
Turn it off and all unlocks first press. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 182 ![]() ![]() |
https://www.ownerinfo.landrover.com/docume...c/G2387182 |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
With it active 1 press unlocks drivers door - second press unlocks complete car. |
Are you referring to the key fob? I've never used the fob I just use the door buttons or the App. So my post is of no use at all 😁😁 130's have feeling's as well you know
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
^ +1
What AndrewS says Gareth you will need to educate your family NOT to slam the tailgate - it’s the only door on the car with soft close! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Yes I’ve worked that one out Tim! I definitely can’t get the rest of the doors to unlock on the second press.
Two presses on locking does indeed super-lock it, but two presses on unlock just results in the drivers door unlocking. This is either on the fob or the button. Going to try again later! Got frustrated with it. 😖 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
From manual,
2-STAGE UNLOCKING To unlock the vehicle and disarm the alarm system, press the smart key's unlock button. The vehicle unlocks in one of two ways: 2-stage unlocking on: Unlocks the driver's door only. A second press is required to unlock the remaining doors and the taildoor. 2-stage unlocking off: Unlocks all of the doors and the taildoor on the first press. To change the vehicle’s 2-stage unlocking status, press the smart key's lock and unlock buttons simultaneously for 3 seconds. The hazard warning lights flash twice to confirm the change. 2-stage unlocking can also be set via the Vehicle menu in the touchscreen. See SYSTEM SETTINGS. |
