Home > General & Technical (L663) > 2 stage unlocking ....
Gareth
Anyone else having a issue with it? Mine refuses to unlock anything but the drivers door when. 2 stage unlock is configured.
Turn it off and all unlocks first press. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #877469 10th Jan 2021 3:08pm
J77
That is two stage unlocking, my Velar is the same one press unlocks drivers door only.
Locking two presses deadlocks the car, on the Velar at least. 24MY 90 D250 HSE, Tasman Blue
Post #877497 10th Jan 2021 3:58pm
Philm
Re: 2 stage unlocking ....
https://www.ownerinfo.landrover.com/docume...c/G2387182
Post #877501 10th Jan 2021 4:10pm
Simon Audi
With it active
1 press unlocks drivers door - second press unlocks complete car.
Post #877546 10th Jan 2021 6:36pm
AndrewS
Are you referring to the key fob? I've never used the fob I just use the door buttons or the App. So my post is of no use at all 😁😁 130's have feeling's as well you know Smile
Post #877553 10th Jan 2021 6:43pm
Tim in Scotland
^ +1
What AndrewS says
Gareth you will need to educate your family NOT to slam the tailgate - it’s the only door on the car with soft close! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #877560 10th Jan 2021 6:56pm
Gareth
Yes I’ve worked that one out Tim! I definitely can’t get the rest of the doors to unlock on the second press.
Two presses on locking does indeed super-lock it, but two presses on unlock just results in the drivers door unlocking. This is either on the fob or the button.
Going to try again later! Got frustrated with it. 😖 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #877590 10th Jan 2021 8:09pm
Philm
From manual,
2-STAGE UNLOCKING
To unlock the vehicle and disarm the alarm system, press the smart key's unlock button.
The vehicle unlocks in one of two ways:
2-stage unlocking on: Unlocks the driver's door only. A second press is required to unlock the remaining doors and the taildoor.
2-stage unlocking off: Unlocks all of the doors and the taildoor on the first press.
To change the vehicle’s 2-stage unlocking status, press the smart key's lock and unlock buttons simultaneously for 3 seconds. The hazard warning lights flash twice to confirm the change.
2-stage unlocking can also be set via the Vehicle menu in the touchscreen. See SYSTEM SETTINGS.
Post #877591 10th Jan 2021 8:13pm
