Home > Puma (Tdci) > Steering issue after dash removal |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 637 |
Take it off again and make sure the blue plastic bit for the indicator return is lined up correctly. Had similar on mine after I changed the steering column and it felt heavy and weird after putting it back together. I had the plastic bit out by 90deg.
Hope it is a similar easy fix for you. |
5th Jan 2021 7:16pm |
Packster82 Member Since: 15 Jul 2020 Location: Cirencester Posts: 24 |
Thanks Scot, I’ll take a look. Fingers crossed it’s a simple fix...too many hours on a wiper spindle already!!
5th Jan 2021 7:41pm |
Thanks Scot, that nailed it. Steering sorted.
9th Jan 2021 11:07pm |
10th Jan 2021 7:49am |
