Home > Puma (Tdci) > Steering issue after dash removal
Packster82
2013 Defender 110 Puma 2.2 CSW Keswick Green
Hi, I’ve just put the dash back having replaced the passenger side wiper spindle, which now all works fine. The problem is the steering, it’s now really sluggish and nowhere near as light as it was before, it’s also really unpredictable on the turn and feels like it’s going to roll every time I turn gradual right or left on a faster road. Ive removed the steering wheel and put back on but there no change.
I removed the dash a few months ago for a different reason and didn’t have any issue with the steering then. Is it likely I’ve knocked something when putting the ignition casing back on...any ideas great received!!
Post #876447 5th Jan 2021 6:49pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Take it off again and make sure the blue plastic bit for the indicator return is lined up correctly. Had similar on mine after I changed the steering column and it felt heavy and weird after putting it back together. I had the plastic bit out by 90deg.
Hope it is a similar easy fix for you.
Post #876454 5th Jan 2021 7:16pm
Packster82
Thanks Scot, I’ll take a look. Fingers crossed it’s a simple fix...too many hours on a wiper spindle already!!
Post #876461 5th Jan 2021 7:41pm
Packster82
Thanks Scot, that nailed it. Steering sorted.
Post #877359 9th Jan 2021 11:07pm
Scotm
Thumbs Up
Post #877384 10th Jan 2021 7:49am
