![]() | Home > In Car Electronics > High beam woes |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11031 ![]() ![]() |
The first thing that comes to mind is the hazard lights switch, but i'm no mechanic/electrician. Clayton.
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Me neither
![]() However, my powers of observation have led me to believe the culprit might be this; ![]() Click image to enlarge ![]() Click image to enlarge Can anyone with some elastictricky knowledge point me in the direction of replacing the now defunct relays? The loom is a Landreiziger , however I cannot find the relays alone on their website Cheers |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
What age ?
Loom is about 2 years and I’m 46 thank you for asking
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Are there not numbers on the base to identify from, other than the terminal numbers?
The plug in bases look like those that you'd use with a standard 30amp relay. Darren
I got a close up picture of the base...the pins are bent so you can see the numbers
![]() Click image to enlarge Going clockwise from the top the numbers are ; 85-36-86-87 Thanks |
It's likely 30 rather than 36 and it matches a standard relay:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17873 ![]() ![]() ![]() |
They should be bog standard relays, widely available. Just check (as LRA says) the pin numbers, these are SAE standard and will confirm the correct part.
Excellent, thanks all
I shall get some ordered ![]() |
HELLA Relay Socket 8JD745801-011
![]() HELLA 007794301 Cover with Weatherproof Mini ISO Relay ![]() Last edited by dorsetsmith on 10th Jan 2021 2:02pm. Edited 1 time in total |
i found Halfords do them, i shall pop down tomorrow and pick up a couple
https://www.halfords.com/tools/fuses-elect...84005.html |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065 ![]() ![]() |
Have our been wading a little to deep then Badger110 ?
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
https://www.12voltplanet.co.uk/twin-make-b...b3EALw_wcB 02' 110 TD5 Double Cab Rebuild Thread
