Home > In Car Electronics > High beam woes
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
High beam woes
My high beam began to struggle whilst i was away in Scotland and i'd like to get it sorted.
High beam doesn't work, either pass or full on, however when i engage pass mode ( pull the stalk towards me ) the trailer light flickers and the hazard lights flicker on the dash.
This doesn't happen when i select high beam.
The blue light indicates on the dash that i'd selected high beam, just nothing actually lights up.
I believe i replaced the stalk not that long ago when i had issues with the indicators so i'm thinking along the lines of it being the stalk as it was a BP part anyway, but thought i'd ask in case someone tells me it's the 3 screw from the right after the diff lock selector has been tightened too much on a weekend Laughing
Post #871708 6th Dec 2020 11:49pm
L110CDL
The first thing that comes to mind is the hazard lights switch, but i'm no mechanic/electrician. Clayton.
Keeper.
Post #872504 11th Dec 2020 9:21pm
Badger110
Me neither Wink
However, my powers of observation have led me to believe the culprit might be this;
Can anyone with some elastictricky knowledge point me in the direction of replacing the now defunct relays?
The loom is a Landreiziger , however I cannot find the relays alone on their website
Post #877263 9th Jan 2021 3:20pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
What age ?
Post #877274 9th Jan 2021 4:11pm
Badger110
Loom is about 2 years and I’m 46 thank you for asking Very Happy
Post #877277 9th Jan 2021 4:31pm
htb2
Wales
Are there not numbers on the base to identify from, other than the terminal numbers?
Post #877284 9th Jan 2021 4:57pm
The plug in bases look like those that you'd use with a standard 30amp relay. Darren
Post #877291 9th Jan 2021 5:12pm
Badger110
I got a close up picture of the base...the pins are bent so you can see the numbers
Going clockwise from the top the numbers are ;
85-36-86-87
Thanks
Post #877315 9th Jan 2021 6:24pm
It's likely 30 rather than 36 and it matches a standard relay:
 Darren
Post #877321 9th Jan 2021 6:39pm
They should be bog standard relays, widely available. Just check (as LRA says) the pin numbers, these are SAE standard and will confirm the correct part.
Post #877324 9th Jan 2021 6:50pm
Badger110
Excellent, thanks all
I shall get some ordered Thumbs Up
Post #877330 9th Jan 2021 7:01pm
dorsetsmith
HELLA Relay Socket 8JD745801-011
HELLA 007794301 Cover with Weatherproof Mini ISO Relay
Post #877342 9th Jan 2021 8:48pm
Badger110
i found Halfords do them, i shall pop down tomorrow and pick up a couple
https://www.halfords.com/tools/fuses-elect...84005.html
Post #877369 9th Jan 2021 11:52pm
DAZ110
Have our been wading a little to deep then Badger110 ? Whistle Wink
Post #877434 10th Jan 2021 12:11pm
rallysteve
Post #877450 10th Jan 2021 1:19pm
