Home > In Car Electronics > Mudstuff double din dash install question
Rallyevo3
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Evening, I have a 2013 110 xs and the radio has packed up, I'm thinking of fitting a mudstuff double din dash, does anyone know if you have to extend the loom to fit this?
Post #876434 5th Jan 2021 6:00pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Basic answer is yes.
It depends which switches you have...and where you choose to position them.
Some will reach, but if I recall correctly I extended the loom for 3 switches.
Time consuming, but not difficult.
Clemmo
Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #876459 5th Jan 2021 7:32pm
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
I have their kit and I did not have to extend the loom for any of the switches. I have a 2015 90 that's missing some switches (rear wiper switches, traction control, light leveling) so your mileage may vary.
Here's a photo of mudstuff's double din kit installed in my defender. The switch panel on the left side is from twisted.
Post #876919 7th Jan 2021 7:56pm
Matt110
Topic diversion.... Is that a checktemp in your dash? Got any closer photos of it? Looks great!
Post #876923 7th Jan 2021 8:09pm
siglo
Yes it is. I found this old picture probably on the original fascia not on the double din. I used a dremel to cut out the hole where the head light leveling switch usually goes. The checktemp screen fits there almost perfectly.
Post #876925 7th Jan 2021 8:21pm
Martin
Site Admin
Quick and even easier now Whistle
https://www.fnltd.co.uk/shop/defender-2002...-p124.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #876926 7th Jan 2021 8:27pm
Clemmo
Wow...expensive thou. Would make it easier.
Perfect if you don’t have the confidence or ability
Post #876948 7th Jan 2021 10:25pm
Martin
Site Admin
Cheaper than hiring a auto electrician to extend your wires, or splattering solder on your dash plastics Whistle
Plug and play, job done in seconds. Cool  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #877024 8th Jan 2021 12:20pm
Vitesse
I made a few of these extender looms a couple of years ago using old modified switch bodies. Glad that someone has now manufactured the plugs for this. Really helped with my stereo install
 2015 90 XS Santorini Black
Post #877337 9th Jan 2021 7:45pm
Bish
2002 Defender 90 Td5 XS CSW Java Black
These are amazing and make the job so simple. You only really need to extend 1 loom if you are careful about which switches you move across. I just extend tithe rear heated windscreen from memory.
Post #877510 10th Jan 2021 4:46pm
Jungle1101
Clemmo
Thumbs Up
Hi, I was wondering if you could tell me how you extended your wiring? Did you use solder or connectors?, if connectors which type are best suited? I am in the process of doing this upgrade and will have to extend switches, I could probably get away with one but would like to do three as it will allow the cables to have some additional length and leave it a bit more tidy (I get no one will see it but I just think it's better to do it to a good standard). I don't have too much experience of this kind of thing so would appreciate any advice.
Post #886995 21st Feb 2021 8:10pm
Martin
Site Admin
Not precisely what you asked but the extension looms we sell now make this job very quick: https://fnltd.co.uk/shop/defender-2002-201...-p124.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #887919 26th Feb 2021 10:53am
