![]() | Home > In Car Electronics > Mudstuff double din dash install question |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1319 ![]() ![]() |
Basic answer is yes.
It depends which switches you have...and where you choose to position them. Some will reach, but if I recall correctly I extended the loom for 3 switches. Time consuming, but not difficult. Clemmo ![]() |
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 ![]() ![]() ![]() |
I have their kit and I did not have to extend the loom for any of the switches. I have a 2015 90 that's missing some switches (rear wiper switches, traction control, light leveling) so your mileage may vary.
Here's a photo of mudstuff's double din kit installed in my defender. The switch panel on the left side is from twisted. ![]() Click image to enlarge |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 688 ![]() ![]() |
Topic diversion.... Is that a checktemp in your dash? Got any closer photos of it? Looks great!
Yes it is. I found this old picture probably on the original fascia not on the double din. I used a dremel to cut out the hole where the head light leveling switch usually goes. The checktemp screen fits there almost perfectly.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Quick and even easier now ![]() https://www.fnltd.co.uk/shop/defender-2002...-p124.html ![]() ![]() |
Wow...expensive thou. Would make it easier.
Perfect if you don’t have the confidence or ability ![]() |
Cheaper than hiring a auto electrician to extend your wires, or splattering solder on your dash plastics
![]() Plug and play, job done in seconds. ![]() ![]() ![]() |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409 ![]() ![]() ![]() |
I made a few of these extender looms a couple of years ago using old modified switch bodies. Glad that someone has now manufactured the plugs for this. Really helped with my stereo install
![]() Click image to enlarge 2015 90 XS Santorini Black |
Bish Member Since: 11 Nov 2008 Location: Hungerford Posts: 433 ![]() ![]() |
These are amazing and make the job so simple. You only really need to extend 1 loom if you are careful about which switches you move across. I just extend tithe rear heated windscreen from memory. |
Jungle1101 Member Since: 21 Feb 2021 Location: Glasgow, scotland Posts: 2 ![]() ![]() ![]() |
Hi, I was wondering if you could tell me how you extended your wiring? Did you use solder or connectors?, if connectors which type are best suited? I am in the process of doing this upgrade and will have to extend switches, I could probably get away with one but would like to do three as it will allow the cables to have some additional length and leave it a bit more tidy (I get no one will see it but I just think it's better to do it to a good standard). I don't have too much experience of this kind of thing so would appreciate any advice. |
Not precisely what you asked but the extension looms we sell now make this job very quick: https://fnltd.co.uk/shop/defender-2002-201...-p124.html
