Home > Modifications & Maintenance (L663) > Fold down table.
Page 1 of 4 1234>
G4R1
Fold down table.
Just wanted to share with you a little modification I have done earlier today. Very pleased with the outcome.
Total cost £80, installation time 1 hour.
Post #876875 7th Jan 2021 4:26pm
Gareth
That’s very neat! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #876877 7th Jan 2021 4:32pm
Simon Audi
A kit of parts - that you fitted or all made from scratch or?
Post #876882 7th Jan 2021 5:02pm
G4R1
It basically a fold-down table for Jeep Wrangler
https://www.amazon.co.uk/dp/B07GWYMKTF/ref=dp_prsubs_1
And a set of brackets
https://www.amazon.co.uk/gp/product/B08HWH...&psc=1
Also, you will need x4 M6 bolts about 30-35mm long.
You also will need to drill x6 6mm holes (4 holes in the table bracket) and 2 holes in the 2 of the 4 angle brackets) 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #876884 7th Jan 2021 5:16pm
Simon Audi
THANKS
Post #876886 7th Jan 2021 5:23pm
denhams
United States
Neat solution. Any rattles? Is it bolted or riveted through the panel? I can't make out from the photos. If it's bolted, how easy is it to remove the panel? 1981 Series III 88 Santana Especial
2020 Defender 110 SE
2023 Tesla Model 3 RWD
Post #876956 7th Jan 2021 11:38pm
SN
Like this... a lot. Bow down
Many thanks! Thumbs Up Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #876961 8th Jan 2021 12:12am
That's very neat - looks like it was always intended to be there. Darren
Post #876970 8th Jan 2021 7:34am
G4R1
It is bolted using the existing holes/nuts, you don’t have to remove the panel. Just remove 4 bolts, 2 on each side of the panel and replace them with longer bolts (about 35mm long) to fix the angle brackets. 3.0L MHVE D200 S Pangea Green+Black Pack
Post #876972 8th Jan 2021 7:59am
DSL
Very nifty indeed. Bow down Bow down Thumbs Up
Post #876975 8th Jan 2021 9:07am
SN
I notice there are a few variants of these tailgate drop tables for Jeeps on Amazon.
This one caught my eye - no idea whether it fits as well as the one above - seems to be about 48mm longer (before the extender is pulled out) so not sure whether it would still fit on the existing Defender bolt holes as shown above (I think that one 600 wide))
https://www.amazon.co.uk/Front-Runner-Drop...K9QZNFGCWQ
Post #876986 8th Jan 2021 10:14am
G4R1
The distance between the existing screws is 660mm, I believe this version will work just fine, obviously will require 4 holes on the back of the table mount or a couple of angle brackets to match existing holes in the tailgate panel.
The version I installed the table itself is 600mm wide including the mounts is 628mm. 3.0L MHVE D200 S Pangea Green+Black Pack
Post #877137 8th Jan 2021 7:40pm
PaulMark
South Africa 2015 Defender 110 Puma 2.2 SW Alpine White
Have this table fitted to mine.
Post #877419 10th Jan 2021 11:03am
That's a very useful table with the pull out board underneath but I've got to ask - why is it off centre? Darren
Post #877421 10th Jan 2021 11:21am
PaulMark
That’s just how front runner installed it and it’s never bothered me enough to warrant drilling more holes in the table.
Post #877425 10th Jan 2021 11:35am
Page 1 of 4 1234>
