Home > Off Topic > What’s the stickiest strongest contact adhesive.
Bluest
Looking for the best adhesive to stick carpet and vinyl to plywood. Not had a lot of luck with aerosol ones, so maybe brush on is better? I used a Screwfix aerosol one to stick vehicle carpet when I fitted out the back of the Landy and it was garbage. 2007 110 TDCi Station Wagon XS
Post #876274 4th Jan 2021 7:42pm
Some of them aren’t good at all as you say.
Just this week I’ve used this one:
https://www.ebay.co.uk/itm/Trim-Fix-500ml-...890.l49292
I haven’t had a problem at all with it, best one I’ve used.
It is indeed a spray type though, but it work well is all I can say. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #876284 4th Jan 2021 8:10pm
kenzle8a
One of my chums who does trimming uses this, it’s pretty aggressive in his own words.
https://www.ebay.co.uk/itm/122242645508
Post #876286 4th Jan 2021 8:19pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I’ve used the 528, super strong quick use contact adhesive, but you’ll need to use in a ventilated area. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #876291 4th Jan 2021 8:28pm
Zed
Day old Weetabix. You need a kango drill to get it off a bowl. WARNING.
Post #876293 4th Jan 2021 8:36pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I need to stick some 3mm rubber mat to plywood (making a platform to groom the dog on)
Thinking of using Evo Stick Impact adhesive - anyone used that?
Post #876303 4th Jan 2021 9:10pm
Bluest
Thanks all, I’m going to try the Evo Stick 528. It has numbers instead of a name so logically must pro-grade not for the DIYers.
Zen- I said I wanted to glue it down, not fuse it at the molecular level! Laughing 2007 110 TDCi Station Wagon XS
Post #876311 4th Jan 2021 9:46pm
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Gorillas wicked stuff, it also won't harm the underside of plastic, there's the water type and the caulk type.
Caulk type is fantastic but it really does take a while to bond I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #876321 4th Jan 2021 10:23pm
Plywood is quite absorbent - you may get better results if you prime it first. Darren
Post #876324 4th Jan 2021 10:30pm
landy andy
Be very careful of using the contact adhesive with rubber mat. It makes the rubber deform with the chemicals, and it doesn’t return to shape.
I’ve had good results with spray adhesive but ply needs to be sprayed with glue as well as covering material, and ideally primed beforehand. I just used watered down unibond/PVA
Post #876344 5th Jan 2021 12:06am
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
You’re not wrong mate
Post #876345 5th Jan 2021 12:24am
Evo Bostik must be good, all the 70's Punks couldn't have been wrong!!
Though they didn't 'stick' around for long!! (RIP my punk school chum, known as Evo) ...true story.
Post #876411 5th Jan 2021 4:22pm
AMBxx
I used Glover bond for sticking carpet to plastic. Sets very quickly and has held up well so far. Not sure if you'd need to prime the plywood first though.
Post #876415 5th Jan 2021 4:36pm
