![]() | Home > V8 > New fuel tank |
Rear tanks were fitted from TD5 onwards so in theory in should be doable. However, there will be brackets on the chassis for the tank cradle and the filler moves to behind the rear wheel so a conversion is not at all straightforward. It's one of those jobs that there isn't an off the shelf solution to and will require a degree of inventiveness to accomplish.
In terms of safety, apart from the leak which obviously needs to be fixed, the location of the fuel tank is way down on the list of issues with a Defender, to be honest. Handling and crashworthiness would be a much bigger concern for a teenager with a V8. A diesel engine would temper the performance and also reduce its' flammability but if safety is the priority then Option B is the better and probably cheaper solution. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17943 ![]() ![]() ![]() |
Fitting a pair of good quality strong rock sliders (or rock and tree sliders) would probably provide as much protection for the tank as moving it to the rear. Your probably statistically more likely to be hit from behind than from the side anyway.
Shuggy110 Member Since: 25 Mar 2018 Location: Perthshire Posts: 58 ![]() ![]() ![]() |
Good thoughts. I had forgotten that my old Td5 90 had the filler at the rear.
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
The tank would be the last of my worries, but if you must then might be more effective to fit a ali fuel cell on the rear cargo area. Retro fitting a rear tank to an early 90 isnt straight forward given all the extra scaffolding on the chassis to support it.
