![]() | Home > General & Technical (L663) > Surprised the Defender doesn't have a heated screen |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
They do have heated front and rear screen... what model does not?
vlad Member Since: 11 Oct 2020 Location: RO Posts: 67 ![]() ![]() |
It's an option.
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
As SA sez, standard, well in U.K. anyway.
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3463 ![]() ![]() |
Yup, definitely standard on UK cars. I’m surprised it wouldn’t be standard fit in other markets. 24MY 90 D250 HSE, Tasman Blue
deaston Member Since: 18 Dec 2020 Location: UK Posts: 150 ![]() ![]() |
What an idiot. I couldn't see it anywhere on my equipment list, but was just being blind. Indeed it does have it.
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Maybe you were reading the spec list from behind frosted specs, or windscreen
![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
And heated seats are standard, again in the UK anyway. Toasty butt from the seats and hands from the screen, sorted!
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Are you using LandRover.com website or LandRover.co.uk to create your spec, there is a difference between ROW and UK specs depending on the website.
My heated screens cleared in a minute this morning at -5C, pre-heater had the rest of the interior up to 20c in the 30 minutes run time too. Hope mine isn’t developing a problem with the front screen heater as the passenger side defrosted sooner than the driver’s but they did both clear completely as did the side windows once warm air started coming out of the vents. I even remembered to set the wipers to winter park mode and turn off the auto on mode. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
Neither heated windscreen nor heated seats are standard in Germany.
Heated windscreen comes as a part of the Cold Climate Pack at 750 Euro. Heated seats are at 380 Euro each for front and second row.[/code] |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
So to be clear, in the UK, you get heated screen in all models? (specifically in my case the S spec
![]() or do you need to spec the Cold Climate Pack? I shall be building a list of 'we should just add these for reason X' items over the next few weeks before factory build spec is frozen. Have already planted this in SWMBO's mind, now we're getting past the initial shock of the number in the bottom right hand corner of the order form... ![]() ![]() ![]() ![]() |
Build yourself a car - on the configurator - download the personal brochure and you will see what you get included as standard - better than you can see during the config process.
But S Model has Heated Screen and Heated Front Seats. |
I wonder if the Defender in my local UK dealer was a non-UK SE model then, as I looked very closely at the windscreen and couldn't see the filaments. So when I (wrongly) couldn't see it on my spec, it confirmed to me that it didn't have a heated screen. |
Cheers - just run the brochure off on lruk against the build I ordered against - and its there!
Just bear in mind also that what you get in the way of heated seats as standard is only heated FRONT seats, rears are not included even in the First Edition, so if you regularly carry rear seat passengers sentive to the cold you’ll have to add heated rear seats on the Interior options section of the configurator where you choose the colour of the interior Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
