Home > Maintenance & Modifications > Additional lighting wiring setups
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Hi All
Im sure this has been asked before but couldnt find anything with search.
How do you guys wire additional external lighting in, spots, light bars etc. Do you wire them seperatly back to the battery each time or install an additional fuse box in the engine bay and wire back to that?
Post #875432 31st Dec 2020 2:23pm
bankz5152
I have a Blue Sea Aux fuse under my cubby box in my 110. All additional/auxiliary electrics run back to that.
Post #875440 31st Dec 2020 2:59pm
discomog
As Bankz says, Blue Sea fuse box and run all auxiliaries through it. You may find it more convenient not to fit it in the engine bay but somewhere in the cab - it's much easier to check and change fuses when it's inside. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #875478 31st Dec 2020 5:46pm
Mine is fused inline directly fed from the alternator, but you can only really add a couple of circuits before it gets too congested on the alternator positive stud.
You will get the best performance and least voltage drop though.
Both my headlights, and dual front light bars are fed this way. Light are on 6mm2 thinwall. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #875494 31st Dec 2020 6:21pm
Should have added, if you have multiple circuits though or many different lighting items to supply then indeed a BS install would be a better option. ____\We|Will|Win/___
Post #875495 31st Dec 2020 6:22pm
TamarBlue11
Thanks for the advice guys Smile
Post #876071 3rd Jan 2021 4:39pm
X4SKP
Hello TamarBlue11
Simple and well made little unit...
https://www.mudstuff.co.uk/products/blue-sea-fuse-block
 SKIP
Post #876082 3rd Jan 2021 5:37pm
