Home > Td5 > Non-starting 2003 110 TD5
Big Bouncy Bertha
United Kingdom 2003 Defender 110 Td5 USW Belize Green
I broke down just before Christmas after the fuel pump had become very noisy. Have replaced pump and filter head, think I have gone through the purge procedure (was probably a little shorter, as filled the filter with diesel before fitting), but she will not start unfortunately... There are no obvious leaks and I checked the new filter head against the old one beforehand, to make sure everything in the stub pipes matched. I know it's a case of how long's a piece of string, but any helpful suggestions before I call in the professionals... Oh and there is around 19 litres of fuel in the tank... Cheers all and have a good evening...
Post #875435 31st Dec 2020 2:45pm
bankz5152
Purge it again can take a few goes. Needs to be fairly quiet when purged
Post #875439 31st Dec 2020 2:57pm
dorsetsmith
Try starting with your pedal down to floor
Post #875448 31st Dec 2020 3:58pm
Big Bouncy Bertha
Many thanks... I have now gone through the purge procedure perhaps 5 times and no noise to speak of, other than a quietly purring pump.. Hey-ho, looks like I'll have to get it checked by a pro.
Post #875456 31st Dec 2020 4:15pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
I just had the same issue.... you did try with pedal to the floor ...and extra battery hooked up as it takes a while - at least with mine๐Ÿ˜… 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #875461 31st Dec 2020 4:26pm
Big Bouncy Bertha
Thanks to all and a Happy New Year
Many thanks to all of you for taking the time to reply to my post... Lots to go on there... Will update when she has burst into life again.... ๐Ÿ˜Š๐Ÿ‘
Post #875501 31st Dec 2020 6:35pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
New pump is not the same as good working pump. I have seen not good pumps from new. Try the fuel pressure, best with some pressure gauge, or just umplug the hose with fuel from pump to engine and place it into a canister. With ignition on, there should be large fuel flow from the hose, like 3 liters in one minute. If it is just barely flowing, you have probably half of the pump not working. "Drobek" = The Small One - Discovery 2, "Blufรญnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #875569 31st Dec 2020 11:23pm
Big Bouncy Bertha
Cheers Tom. I am hoping though that given its a new VDO pump it is OK... Will give your suggestion of a basic check a go though... ๐Ÿ˜Š๐Ÿ‘
Post #875629 1st Jan 2021 12:03pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Did you find the solution to this? ๐Ÿ˜€ 2005 TD5 90 CSW XS
Post #881715 29th Jan 2021 1:31pm
