Home > Technical > Frozen lock
Countryman2
United Kingdom 2015 Defender 90 Other XS CSW Scotia Grey
Frozen lock
Any advice on dealing with a frozen lock on the drivers door of a Puma with central locking? The tab is down on the inside. Managed to get in through passenger side but was not an easy climb from there to drivers seat. Not very technical so not up to dismantling the door. Thanks.
Post #875339 30th Dec 2020 10:32pm
dorsetsmith
hot water and key
place metal part of the key in to hot water and then in to lock barrel
or heat gun on low heat
abus lock lubricant ps88 will help stop icing up
Post #875354 30th Dec 2020 11:52pm
Countryman2
Thanks. Will try the key in hot water trick.
Have just ordered some of the lubricant.
Post #875383 31st Dec 2020 7:52am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
The lack of an image of a scotsman ice skating across the water was a bit disappointing if i'm honest
Post #875392 31st Dec 2020 9:50am
familymad
I found GT85 good for them 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #875396 31st Dec 2020 10:02am
Countryman2
Thanks everyone. Now unlocking and locking properly.
Post #875400 31st Dec 2020 10:30am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
This is a real pain when this happens, also bouncy door seals! I use a silicon lubricant in locks and on door seals prior to winter kicking in seems to help.
Sounds like your sorted now anyway Thumbs Up
Post #875404 31st Dec 2020 10:41am
Countryman2
Thanks Mike. Can I put lubricant on the rubbers around the door windows then as they were frozen shut as well?
Post #875409 31st Dec 2020 11:09am
Mike c
Assuming you mean the weather strip at the bottom of the windows on the doors, I dont see why not as long as it's a safe for rubber lubricant such as silicon, the only thing with putting any lubricant these is you dont want any lubricant getting on the glass itself.
Personally I dont bother with that and scrape the windows clear before attempting to open them.
Post #875414 31st Dec 2020 11:24am
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
Gummi Pflege is what you need to treat the seals with, use it on my 90 and also on an SLK. It stops the seals freezing but also keeps them soft and supple
Post #875473 31st Dec 2020 5:30pm
cee-b
Yep, +1 for Gummi Pflege (or Rubber Care, if you don't speak german) for the seals.
To prevent my drivers' door lock freezing (the passengers' doesn't as it is next to the house) I just made up a protective sleeve from pipe lagging. Cut slots so it fits onto the handle and block the ends - it works a treat for me.
Post #875498 31st Dec 2020 6:30pm
Countryman2
Thanks for the suggestion. Just ordered some from Amazon.
Post #880414 23rd Jan 2021 10:52pm
UtilityTruck
Laughing 2014 Keswick Utility 2.2
Post #880444 24th Jan 2021 8:24am
LR90XS2011
ACF50 for the locks a silicone spray for the rubber seals DEFENDER 90 TDCI XS,
Post #880450 24th Jan 2021 8:55am
Martyn668
Bit of Vaseline in the keyhole as winter approaches.
Post #880500 24th Jan 2021 11:01am
