![]() | Home > General & Technical (L663) > MHEV - Technical Details |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2747 ![]() ![]() |
I don’t think the diff shows on that screen, the 20.5MY I drove back in August was the same. It shows on the centre screen though.
Might show if you’re in an off-road TR mode, I only drove it on the tarmac at that time. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3482 ![]() ![]() |
As above I think when you put it in a TR setting it shows more. It does on the Velar at least.
Julep Member Since: 07 Nov 2020 Location: Jersey Posts: 25 ![]() ![]() |
Yup, can confirm that the Locks are only shown on the center screen.
![]() Click image to enlarge But that's an interesting image Simon, The icons showing the peddle and breaks makes me think of the Energy harvesting the MHEV is supposed to do during breaking, but to be honest I have not found any features that relate to MHEV on mine?
True Retroanaconda, it just appears to be a very expensive Stop/Start system. ![]() Julian 110 County Station Wagon V8 Freelander Sport Td4 Discovery 4 XS TDV6 Defender X 110 P400 |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
The P400 MHEV battery I think only powers the supercharger the diesel mhev batteries only power start/stop system
Thanks Digger2000,
So the Defender MHEV is nothing like the Evoque MHEV? https://www.landrover.com/liveforthecity/e...-what-mhev I must admit I was hoping I was being 'slightly' eco friendly, (just trying to redeem my years of driving the CSW V8 ) ![]() ![]() Freelander Sport Td4 Discovery 4 XS TDV6 Defender X 110 P400 |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
Which engine did you get in your car?
I think its similar to the Evoque
It uses the fancy starter to put back power. But I think it does not shut off the engine at 11 MPH but lower like 1 or 2.. How much of what I have said is fact or fiction - I can not be sure... but thats the best I can piece together based on the limited and conflicting information out there. Worse case the MHEV - would provide 12V instead of the alternator during acceleration - to remove that load. |
It’s start/stop but with add-ons. The iGUIDE manual has detail of how the system works, it basically shuts the engine off at very low speed and can then use the motor/generator thing to get it going again very quickly.
Like most modern vehicle systems it will get turned off by most drivers as they’re nothing but annoying. Auto wipers and lights for example, and lane assist. |
You have a link - because I can only find the 2020 version and that did not have the MHEV and even if I look on the 2021 Discovery I can not find it...
MANY THANKS |
https://www.landrover.co.uk/vehicles/defender-2020/models.html
This is the one I got, scroll down to the Defender X and it states "3.0L PETROL MHEV P400 AWD AUTO" Thanks Retro, just found the text in the iGuide under the "Auto Stop on the Move". Trying to move at less than 1mph is going to be tricky but will try it, but in all honesty that makes it pretty useless. 110 County Station Wagon V8 Freelander Sport Td4 Discovery 4 XS TDV6 Defender X 110 P400 |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Hopefully it will cure the problem that other Land Rover cars have suffered with the “Low battery, start engine” message that was often not related to the main battery but the 2nd battery for the Auto Stop/Start that wasn’t charging properly. Now there’s no need for the 2nd battery - it’s become a big capacitor instead if being an accumulator? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
There’s a 48V battery under the boot floor I believe, which I presume is the energy store for the MHEV system.
Mines due to arrive in the next few weeks so I’ll get some pics when it does. |
![]() Click image to enlarge Standard and MHEV boot floor |
