Home > Puma (Tdci) > 2.4 tdci 2008 Thermostat
Alex von Staffeldt
Denmark 2008 Defender 110 Puma 2.4 SW Alpine White
Im sure this has been a question before, but i cant find an aswer that helps me.
I have had issues with overheating in my Defender 2.4 from 2008.
So far i have changed: coolant pump, thermostat (next to radiator) new radiator and fitted a fan spacer.
Now my problem is that there is almost no heat coming in the cabin.
I have done a fulle bleed several times and nothing helpes.
I have been told that there is 2 thermostats, but cant find the location on the second.
Does anyone know where the 2nd thermostat is located ?
Thanks in advance, and wishing you a nice weekend, Cheers. Defender 110 Puma 2.4 tdci
Post #872587 12th Dec 2020 3:10pm
Greyman110
Does the heater control valve get hot when the car is warmed up?
If it does, check that the cable behind is working by moving the temp control knob in the cabin from cold to hot and that should open and close the valve. You will be able to see the position of the valve change at the back.
Post #872598 12th Dec 2020 4:09pm
Alex von Staffeldt
Hi Greyman110...
Back again Laughing
The valve works and it is hot as the tubes going into the valve. I changed the valve last year, as it was leaking. The cable works just fine.
But the hoses that goes from the valve into the cabin varmer are only semi varm. So i am convinced there is either Censored in the hoses and no circulation or it could be an air pocket in the radiator in the cabin varmer ! Defender 110 Puma 2.4 tdci
Post #872617 12th Dec 2020 6:19pm
It could also be an internal fault with the heater valve, so that the coolant is always bypassing the heater matrix irrespective of the position of the control.
The heater valves are extremely poor quality, cheaply made, and not very durable. They are also shockingly expensive from Landrover, but cheaper alternatives are available (search this forum for alternatives).
Post #872623 12th Dec 2020 7:20pm
dorsetsmith
heater valves
ALFA ROMEO 77363342
CITROEN 6448P6
FIAT 77363342
LANCIA 77363342
PEUGEOT 6448P6
Post #872628 12th Dec 2020 7:36pm
Alex von Staffeldt
Would it be ok to bypass the valve, so the heat goes directly into the cabin ? Defender 110 Puma 2.4 tdci
Post #872648 12th Dec 2020 9:00pm
dorsetsmith
this link good read re your control valve
https://www.defender2.net/forum/topic54969-15.html
Post #872650 12th Dec 2020 9:23pm
Alex von Staffeldt
I Will have a look at it Monday, since it's family hunting tomorrow 😜
Thanks Guys for the help.
I'll keep you updated 🙂 Defender 110 Puma 2.4 tdci
Post #872663 12th Dec 2020 10:21pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
dorsetsmith wrote:
heater valves
ALFA ROMEO 77363342
CITROEN 6448P6
FIAT 77363342
LANCIA 77363342
PEUGEOT 6448P6
Great info, thank you very much! Thumbs Up Roaming around 🇳🇴🇨🇭
Post #899705 23rd Apr 2021 11:21am
