|  | Home > Puma (Tdci) > 2.4 tdci 2008 Thermostat |
| Alex von Staffeldt Member Since: 06 Nov 2017 Location: Copenhagen Posts: 57      |
 Im sure this has been a question before, but i cant find an aswer that helps me.
 I have had issues with overheating in my Defender 2.4 from 2008. So far i have changed: coolant pump, thermostat (next to radiator) new radiator and fitted a fan spacer. Now my problem is that there is almost no heat coming in the cabin. I have done a fulle bleed several times and nothing helpes. I have been told that there is 2 thermostats, but cant find the location on the second. Does anyone know where the 2nd thermostat is located ? Thanks in advance, and wishing you a nice weekend, Cheers. Defender 110 Puma 2.4 tdci | ||
|  12th Dec 2020 2:10pm |
| Alex von Staffeldt Member Since: 06 Nov 2017 Location: Copenhagen Posts: 57      | Hi Greyman110...
 Back again   The valve works and it is hot as the tubes going into the valve. I changed the valve last year, as it was leaking. The cable works just fine. But the hoses that goes from the valve into the cabin varmer are only semi varm. So i am convinced there is either  in the hoses and no circulation or it could be an air pocket in the radiator in the cabin varmer ! Defender 110 Puma 2.4 tdci | ||
|  12th Dec 2020 5:19pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | It could also be an internal fault with the heater valve, so that the coolant is always bypassing the heater matrix irrespective of the position of the control.
 The heater valves are extremely poor quality, cheaply made, and not very durable. They are also shockingly expensive from Landrover, but cheaper alternatives are available (search this forum for alternatives). | ||
|  12th Dec 2020 6:20pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | heater valves
 alternatives are available ALFA ROMEO 77363342 CITROEN 6448P6 FIAT 77363342 LANCIA 77363342 PEUGEOT 6448P6 | ||
|  12th Dec 2020 6:36pm |
 Would it be ok to bypass the valve, so the heat goes directly into the cabin ? Defender 110 Puma 2.4 tdci | ||
|  12th Dec 2020 8:00pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | this link good read re your control valve
 https://www.defender2.net/forum/topic54969-15.html | ||
|  12th Dec 2020 8:23pm |
| Alex von Staffeldt Member Since: 06 Nov 2017 Location: Copenhagen Posts: 57      | I Will have a look at it Monday, since it's family hunting tomorrow 😜
 Thanks Guys for the help. I'll keep you updated 🙂 Defender 110 Puma 2.4 tdci | ||
|  12th Dec 2020 9:21pm |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 435      |
 Great info, thank you very much!  Roaming around 🇳🇴🇨🇠| ||
|  23rd Apr 2021 10:21am |
| Posting Rules
