![]() | Home > Td5 > Should it light up |
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 192 ![]() ![]() ![]() |
Probably best if you can see the switches in dark.
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 786 ![]() |
Easies way to find out is to look behind the panel to see if there any bulbs and wiring.
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
The switches should be backlit in greenish white except for the hazard switch triangle which should be orange/red. These are filament lamps so don't last forever but can be replaced when they die. See https://www.defender2.net/forum/topic16125.html |
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 ![]() ![]() ![]() |
Thanks intercept. Will check it out
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
The OP is referring to the small panel down to the right hand side of the steering column on pre-2002 dashboard.
I don’t think these switches are supposed to be backlit. The hazard switch lights up when in operation. |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 941 ![]() ![]() ![]() |
I had a 300tdi with the similar switch arrangement as early td5s, I dont think they are backlit as said above, I think the only difference was that the heater controls were illuminated on td5s.
Ok. Really couldn’t remember when I drove in the dark last time if they were backlit. Thanks for the responses
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Mine have never lit up unless they were turned on. I ended up converting my switches to back lit by disassembling and reassembling combined switches using old hazard switches.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
