Home > Puma (Tdci) > 2.4 Puma. Lazy starter?
DavyG
My 2.4 started playing up a couple of weeks ago. At first I thought it was the battery on its way out. A few days ago it got progressively worse. The engine would crank over for a second or two, then stop as if the battery had flattened. Switch ignition off, try again and it would start fine. Yesterday I had to do 3 - 4 times before it would start. Today, after the same 3 - 4 times this morning, it won't turn over at all.
I've fitted a new battery (didn't make any difference)and checked the wires running to the starter.
Any suggestion before I pull off the starter motor?
Thanks,
DG
Post #869799 26th Nov 2020 9:09pm
dorsetsmith
ignition switch in its self is common fault on post 07
Post #869801 26th Nov 2020 9:18pm
Oldowner
Mine did exactly that. Starter motor was tired and gave up completely not long after.
Post #869802 26th Nov 2020 9:21pm
Mine's been doing that randomly and intermittently for the last ten years. Sometimes you turn the key and it is really flat-battery-sluggish, try again and it cranks normally. I've been carrying a spare starter motor under that rear seat just in case I need to carry out a roadside swap for ten years!
Post #869807 26th Nov 2020 9:46pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I’m having the exact same at the moment !! Got a new starter going in next week I hope as can’t be let down with my big plant trailer and a 2.5 tone digger on it in a back lane Big Cry , I’ve checked earths and all good and as you I fitted a new battery a couple weeks ago Neutral
Stew
Post #869809 26th Nov 2020 9:54pm
DavyG
Pulled out the starter motor today and 3 hours later with a few expletives.....problem solved. Smile
Post #869990 27th Nov 2020 7:58pm
