![]() | Home > Td5 > TD5 Not startin! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Welcome!
Could be a dicky starter motor. Might be worth a try with a bump start? When my starter played up it would turn over but not start, but would with a bump/tow start. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Have you verified or checked the following:
1- Oil in the ECU plug? 2- Faulty crank position sensor? 3- Ensured FP and Main relays are working and are well seated with no corrosion on the connectors? 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
JohnPaynter Member Since: 23 Nov 2020 Location: Falkirk Scotland Posts: 21 ![]() ![]() ![]() |
Sorry should have mentioned that
I tried bump starting and nothing changed...pretty sure the starter motor is ok...it almost screams to me of a fuel problem thanks 4RF RDS 1. No there isn't any oil in the ECU plug, checked the ECU plenty of times... 2. That seems to be my next plan of attack so hopefully that should fix it... 3. Not tried that, will give that a go thanks...👍😁 |
It could be lots of things, unfortunately. Given your description, it could be damaged wiring but it could equally just need the immobiliser re-syncing with the fob. Darren
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 77 ![]() ![]() ![]() |
Have you checked the ecu status? Sounds like it could possibly be that the 10as needs repairing to the ecu. Have you got access to a nanocom? They’ll usually attempt a little fire at the very beginning then just crank and crank. Have you had any diagnostics on it?
That's what I'm worried about landrover anorak
Have checked with a nano com...no codes...also think the guy that checked it resynced the immobiliser tothe fob...it now locks and unlocks... I really am hoping it is just a crank position sensor but we will see |
There is a lot of damaged wiring...there is a wire leading to nowhere next to the fuel filter, the kids that ruined it have also snipped wires leading to the doors and some of the centre console ones...
I think all bets are off until the wires are sorted. Maybe worth working out what doesn't work and go from there.? 1999 Defender TD5 110
Ok, I'm not much of a mechanic at all...only 16😶but I was hoping that it would run as it was, and that those damaged wires weren't going to affect getting it running
So I take it I should get working diagrams and work out what's missing then? |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 ![]() ![]() |
The ECU is fine as i have taken it out and tried it on my friends td5
thought you had to code the ECU to the AS10 for it to work recommend you get a Hawkeye or nanaocom , takes so more guesswork out of the equation 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
link to diagrams https://1drv.ms/b/s!AtZSoWFHDgnGlQeAGaPfIamVrwlG?e=Zjc5MF |
Check your battery connections (both ends of each cable) and check the voltage at the fuel pump relay.
The relay will not close unless it receives a decent signal. Despite cranking rapidly your battery may not be up to requirements and you may need a new one. How old is it? Try jump starting with a second battery in parallel. ![]() |
battery is relatively new I think but I've tried jump starting and have charged the battery as well
Ok will try all these suggestions, I really am quite a newbie with mechanics so may not understand everything, alsocant do much time on the land atm as I am finishing off rebuilding a classic tractor so will give it a bash in a place weeks time Is the fuel pump relay an issue if I've replaced the fuel pump and getting 4 bar at the fuel pressure regulator? |
Multimeter also good for electric fault finding to https://1drv.ms/u/s!AtZSoWFHDgnGhRik7BVm8l49kYPK?e=wSz1ZS Last edited by dorsetsmith on 23rd Nov 2020 11:13pm. Edited 1 time in total |
