![]() | Home > Off Topic > Straightening warped chequer plate |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Without damaging the surface, your only real option is to put small packers under the centre of the panel and gently clamp the edges past 'flat', slowly increasing the packers until it springs back flat, bit at a time until its acceptable.
good luck Keith |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
I think it might come to that.
Managed to get some warpage out of the metal. I ended up supporting two corners and bouncing up and down on the metal to bend back in to place. Clamping didn't work. There is still a section that needs warpage removing. This is towards the front edge, where the metal curves over the front of the bonnet. 1999 Defender TD5 110
| All times are GMT |
