Home > Off Topic > Straightening warped chequer plate
excossack
I took the bonnet chequer plate in to get blasted and powder coated. I was advised it might warp and it has.
The metal now has a bow it in. (the edge at the top of the bonnet)
What's the best way of removing this warp? Currently clamped flat with G-Clamps but I don't think this will pull it back to shape. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #869104 23rd Nov 2020 11:37am
ickle
Without damaging the surface, your only real option is to put small packers under the centre of the panel and gently clamp the edges past 'flat', slowly increasing the packers until it springs back flat, bit at a time until its acceptable.
good luck
Keith
Post #869113 23rd Nov 2020 1:50pm
excossack
I think it might come to that. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #869118 23rd Nov 2020 2:24pm
excossack
Managed to get some warpage out of the metal. I ended up supporting two corners and bouncing up and down on the metal to bend back in to place. Clamping didn't work. There is still a section that needs warpage removing. This is towards the front edge, where the metal curves over the front of the bonnet. 1999 Defender TD5 110
Regards
John M0VAZ
Post #872398 11th Dec 2020 10:22am
