![]() | Home > In Car Electronics > How do I crimp these switch terminals? |
sailawaybrad Member Since: 14 May 2016 Location: Nr Exeter Posts: 47 ![]() ![]() ![]() |
Hi guys, installing a rear work light and was planning on using the last factory spot on the dash to use a heated seat switch with the facia changed. I’ve got this kit: https://defenderupgrades.co.uk/product/ypc...-contacts/
But I’m struggling on finding something that will crimp the wires properly....ideas? 2011 2.4 110 Utility Wagon 1963 2.25 88 Soft top |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138 ![]() ![]() ![]() |
Insert type C "open barrel terminal"
Thanks all! 2011 2.4 110 Utility Wagon
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 336 ![]() ![]() ![]() |
I always make a mess of crimping terminals! I think retailers should offer the option of 50% extra terminals when you order! It would help tw@ts like me!
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363 ![]() ![]() ![]() |
Just a thought... Which switch is missing in your dash? Behind the switch blank in the dash you will likely find unused wiring which you can repurpose. I did this to used the rear wash wipe circuit to switch my winch relay. My double cab doesn't have a rear wash wipe so I was able to pick up from the washer pump connection in the engine bay > 110 XS Double Cab
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
I supply the 5-way switch connectors with 6 x terminals. In the majority of applications the switches use only 3 or 4 terminals. The only switches that I can think of, that use all 5 terminals, are the aircon and fresh/recirculated air switches on the Freelander-1 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
