![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
YRM sell new mounts which can be welded on to the axle.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3595 ![]() ![]() ![]() |
Yes, seen the YRM brackets. But I thought welding with welding I will try to repair and fill the missing metal on the existing one. Also cutting the old bracket, which otherwise is in perfect condition, is quite a job I guess.
Another option I might consider is cutting a strip 25mm on either side of the damper hole and then weld a 50mm wide flat bar, same thickness as the spring mount, pre drilled with the correct size hole for the damper. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
That would work, but the bracket is a tenner and by the time you’ve got the welder and grinder out it’s surely better to just replace the whole thing? Then you know it’s all sound.
I have welded a thick washer over the hole in the past to get my by. |
Yeah, parts are relatively cheap. The problem is that once they are shipped to my home address the total price is doubled or tripled at the least.
![]() I think so far I have spent 4 digit sum only in shipping costs. Have to be careful that the Mrs is not looking. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Pictures of the modified pan head bolts to be used on the door hinges.
![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
On with the driver side door restoration. It is in remarkably good condition, although it did had some welding many years ago. But generous amount of wax (which now is a pain to clean off) has preserved it well.
Even though it is not rusted, I took the decision to de skin the lower half for proper cleaning, inspection and because the original glue between the skin and frame has failed. The passenger side door I re glued the skin with polyurethane glue, and taping on the skin feels really solid. I like to get a nice thud when shutting the door. Was also surprised to see that the LandRover did not weld the inside of the frame. Really good thinking.. they knew people will be replacing the lower section so often. Unsure if I should get the welding set out... but also door did not fall off 32 years later either. ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
great thread, cant wait to see the end result DEFENDER 90 TDCI XS,
Got delivery of some new rubber. Shipping was a little bit more than I had anticipated
![]() But the smell of fresh vulcanized rubber made me happy again. Nothing special, fairly common combination... but I think will suite the scheme I am going with. Rims will stay white for now. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Good choice!! Can't wait to see them on the finished Defender!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanks. I hope the rubber does not rot before the project is finished.
![]() Today was a stressful day... well no stress for me, but stress on the engine crane that has lifted the engine and gearbox out of the chassis. Will upload some pictures once I get them. Was really easy with all except the bulkhead removed. I am now crying for space ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1898 ![]() ![]() |
Great wheel & tyre choice, they will look amazing
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
So had a sneak peak into the engine with an endoscope. Decided to try to have a look through the intake valve of cylinder 3 at intake peak.
To describe the picture, bottom part is the intake valve. Top part is the valve seat and bore. Middle part is the piston. Seems like there is a crack in the piston.. that would be along and above the gudgeon pin. I was already planning for new pistons. I hope the bore is fine as could only find standard size, that is of good quality with coating. Will know when the head comes off! ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Got to do some work on the drivers door. Now primed and ready for top coat.
