Home > Puma (Tdci) > Help with part number/stockists - one piece Rear Halfshafts
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Looking through a few threads and I think it’s time I fitted one piece rear halfshafts. Quite happy that the Britpart offering is the way forward in terms of cost/benefit but I’m at a point where I can’t see exactly which one to order. I have a MY2013 110 - which parts do I need? Thought I was sorted but a couple of sites have a MY2015 option which is making my head hurt...I’ve no idea if this part would be different for the very last puma but would like to order correctly first time...TIA
Post #867642 16th Nov 2020 6:08am
williamthedog
Give Steve Parkers a call, they do the complete kit. Half shafts, gaskets and bolts. Thumbs Up
Post #867643 16th Nov 2020 6:25am
LR90XS2011
I got 2 perfect ones from a disco for £10
loads of play removed and just fine if you are not planning on rock crawling DEFENDER 90 TDCI XS,
Post #867645 16th Nov 2020 6:53am
I suspect that the reason you're seeing them for 2015 onwards is because they fitted them as standard to the last of the vehicles. The parts are identical for earlier models, though. Darren
Post #867650 16th Nov 2020 7:39am
jst
This is thebsimplist and cheapest way to do it. Something most on here seem worried about for some reason. People did this for years using disco shafts on this onwards. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #867661 16th Nov 2020 9:57am
MussEd
Thanks for all the replies, can’t see it in Steve Parkers site. I may need to *inhales* phone them up!
Post #867706 16th Nov 2020 2:28pm
The 'some reason' is that the Discovery shafts aren't, strictly speaking, substantial enough for use on a 110. They're ok for a 90 - they shared the same parts back in the day - but the genuine 110 shafts are significantly thicker. As we all know that LR don't spend money upgrading parts unless they absolutely have to, there must be a good reason for it. Darren
Post #867714 16th Nov 2020 3:33pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've had the Disco rear ones in my 2014 110 van for over a year with no problems. I do only use it on tarmac though.
They're about 4mm smaller in diameter than the originals, although the ground surfaces for the seals and the splines are identical.
Post #867729 16th Nov 2020 4:48pm
