![]() | Home > Puma (Tdci) > Help with part number/stockists - one piece Rear Halfshafts |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Give Steve Parkers a call, they do the complete kit. Half shafts, gaskets and bolts.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
I got 2 perfect ones from a disco for £10
loads of play removed and just fine if you are not planning on rock crawling DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
I suspect that the reason you're seeing them for 2015 onwards is because they fitted them as standard to the last of the vehicles. The parts are identical for earlier models, though. Darren
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8318 ![]() ![]() ![]() |
This is thebsimplist and cheapest way to do it. Something most on here seem worried about for some reason. People did this for years using disco shafts on this onwards. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 361 ![]() ![]() ![]() |
Thanks for all the replies, can’t see it in Steve Parkers site. I may need to *inhales* phone them up!
The 'some reason' is that the Discovery shafts aren't, strictly speaking, substantial enough for use on a 110. They're ok for a 90 - they shared the same parts back in the day - but the genuine 110 shafts are significantly thicker. As we all know that LR don't spend money upgrading parts unless they absolutely have to, there must be a good reason for it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I've had the Disco rear ones in my 2014 110 van for over a year with no problems. I do only use it on tarmac though.
They're about 4mm smaller in diameter than the originals, although the ground surfaces for the seals and the splines are identical. |
