Home > Technical > Headlight Levelling Plugs
grafty99
Afternoon all Thumbs Up
I've come to fit headlight levelling motors to my 90 only to find that 17 years of flopping around in the inner wing hasn't done the original plugs any favours Rolling Eyes
I'd rather not buy new wing looms for each side so wonder if anyone knows a source for the 3 pin plug? Failing that if the pins are available separately to rebuild the plug?
Thanks in advance Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #867492 15th Nov 2020 12:24pm
PaulMc
I've got the the 3-way connectors and terminals.
I've also got a few of the (now discontinued) VW rubber boots.
PM me Thumbs Up Paul.
Post #867494 15th Nov 2020 12:50pm
Out of interest where did you get your motors from, i’ve got a dodgy one that needs replacing. QRZ 2e0vpf
Post #867495 15th Nov 2020 12:50pm
Martin
Site Admin
The white plug part is YPC10426 - £1.23+VAT from an LR dealer. Doesn't come with the terminals.
I can get them and supply either the housings, terminals or both as a kit.
Edit: beaten by Paul  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #867496 15th Nov 2020 12:52pm
grafty99
PM me Thumbs Up
Thanks Paul, pm inbound Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #867533 15th Nov 2020 4:16pm
grafty99
I got mine from here as a complete kit with the backing rings Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #867534 15th Nov 2020 4:16pm
grafty99
Thank you, Martin Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #867535 15th Nov 2020 4:17pm
skytrucker
Jersey 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Headlight Levelling 2007 Defender
I have been referring to LR Workshop, With investigating putting Headlight Levelling Motors in
I Have the C0093 Plug (YPC10004) behind the Centre Console, and have purchased the Switch to plug in.
I know I have to replace the Headling bowls and purchase motors.
My Query is about the Wiring in the Engine Bay, to connect the Motors to the Connecters C1264/C1265 LH Side & C1266/1267 RH Side
I have looked to see if there is the Plugs available behind the Headlights, but not being able to see any in the area, could they be taped back further along the loom or simply not originally wired in.
I have seen the Harness Link AMR 5833 (AMR5853) that looks like the plug looks similar to the light plugs (not Headlight C0011)
Any advice / knowledge will be gratefully received
Rgds
Paul Current Landrover - 2007 Puma Hardtop
Pervious Landrover - 200Tdi Defender 1991
Driven Various Military Landrovers since 1978
Post #946413 20th Mar 2022 10:17pm
