![]() | Home > Technical > Headlight Levelling Plugs |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
Afternoon all
I've come to fit headlight levelling motors to my 90 only to find that 17 years of flopping around in the inner wing hasn't done the original plugs any favours I'd rather not buy new wing looms for each side so wonder if anyone knows a source for the 3 pin plug? Failing that if the pins are available separately to rebuild the plug? Thanks in advance 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Out of interest where did you get your motors from, i’ve got a dodgy one that needs replacing. QRZ M8VPF
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
The white plug part is YPC10426 - £1.23+VAT from an LR dealer. Doesn't come with the terminals.
I can get them and supply either the housings, terminals or both as a kit. Edit: beaten by Paul 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks Paul, pm inbound 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I got mine from here as a complete kit with the backing rings 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thank you, Martin 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| skytrucker Member Since: 08 May 2011 Location: Jersey CI Posts: 1
I have been referring to LR Workshop, With investigating putting Headlight Levelling Motors in
I Have the C0093 Plug (YPC10004) behind the Centre Console, and have purchased the Switch to plug in. I know I have to replace the Headling bowls and purchase motors. My Query is about the Wiring in the Engine Bay, to connect the Motors to the Connecters C1264/C1265 LH Side & C1266/1267 RH Side I have looked to see if there is the Plugs available behind the Headlights, but not being able to see any in the area, could they be taped back further along the loom or simply not originally wired in. I have seen the Harness Link AMR 5833 (AMR5853) that looks like the plug looks similar to the light plugs (not Headlight C0011) Any advice / knowledge will be gratefully received Rgds Paul Current Landrover - 2007 Puma Hardtop Pervious Landrover - 200Tdi Defender 1991 Driven Various Military Landrovers since 1978 |
