![]() | Home > Series Land Rovers > What rims have I got?! |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
Most Land Rover rims will have a part number stamped on them.
As for sizes, depends what you are wanting to do really. Series rims are 5.5" wide (in terms of bead area). They can fit 7.50 x 16's tyres and smaller. Most tyre makers will suggest a 6.0"j rim for a 235/85R16. So you'd need a 90/Defender rim for this size. Many Series rims are also tubed rims. Which means it is dangerous and illegal to run a tyre without a tube in it. You can ID this on if there is an extra bulge or not on the bead area of the rim. |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 342 ![]() ![]() ![]() |
The ones shown have the rim riveted to the centre, so they are tube type.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Traditionally rims for SWB models were 5" whilst those for LWB were 5.5" I think. SWBs had 6.00x16 tyres whilst LWBs had 7.50x16 tyres.
Wheel rim width is measured inside of the two rims so if you've measured what I think you've measured, you have some standard SWB wheels. As v8bob says, they're for tubed tyres.
![]() Some very early models had 4.5 inch wide rims but they're really not very common. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 ![]() |
Thanks for all the responses. I posted the same question on the S2 forum and the consensus there seems to be that they are Kelsey Hayes wheels, and most likely for a trailer or other lighter vehicle. Given that and the fact they're for tubes means I probably won't use them on my car, so if anyone wants them and can collect from Haslemere, Surrey, they're free to a good home!
tbh the easiest way for Land rover 'looking' rims. Is to buy some for a 90/Defender. They will fit straight on, are wide enough for a 235/85 and are tubeless. Should also be easy and cheap to pick up.
I didn't mention them in my post because they are so rare and collectible (like the original pattern of 543384 or genuine 569203 rims)! Or genuine S1 split rims, for that matter. |
Thanks, that's what I'm aiming to do - just these were cheap and local so thought they might be worth a punt! |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
No they aren't. Standard Defender rims are only 5.5" wide, suitable for sizes upto 7.50R16. 235/85R16 will require wider rims such as wolf rims or alloys. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
