Home > My Defender > An Anorak's Utility Station Wagon |
No fault codes recorded for this, I'm afraid.
The 2.2 does include a feature that keeps the revs up slightly when changing gear. It should be barely noticeable in normal driving, though. I'm only really aware of it on those occasions where you go to change up and then something happens and you abort. If yours is holding at 2000 rpm then that sounds like something isn't right. Best to fix your MAF wiring to discount that before fiddling with anything else, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Oct 2020 9:18pm |
No problem.
It's sometimes quite difficult to diagnose problems over the 'net that you only hear or feel but on the face of it, it sounds like your rev hanging feature is working as it should. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Oct 2020 6:28am |
Mitchnotrich Member Since: 27 Apr 2019 Location: Worcestershire Posts: 41 |
Thanks Darren, your walk through really helped me fit my Nakatanenga RAI. They still seem to have an aversion to sending fitting instructions.... and yes, pulls away much more smoothly and I don’t have a remap (yet...) Cheers. Rich 90 - Gone but not forgotten 200 tdi - sold for a song 3 Discoveries - 1/2/3 - cost me a fortune but loved 'em all 2.4 Puma 90 - Current obsession |
16th Oct 2020 3:33pm |
That's great to know, Rich. Glad to have helped. Darren
16th Oct 2020 9:40pm |
Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 62 |
Great thread!
How are you getting on with the Britpart spare wheel carrier and does it change the increase height / position of the spare wheel? I’m planning to fit a NATO hitch onto the crossmember in the near future and from what I’ve read there is very little room between the hitch and spare wheel?.. |
2nd Nov 2020 8:41pm |
Thanks Andy.
The wheel carrier is great. I do need to re-fit it at some point but that's to substitute some of the bolts for stainless ones that didn't arrive in time when I first fitted it. I haven't measured the height of the wheel but looking at before and after photos, I'd guess it's an inch or so higher now than on the original wheel carrier. That should make all the difference for a NATO hitch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 2nd Nov 2020 10:22pm. Edited 1 time in total |
2nd Nov 2020 9:59pm |
Thanks Darren!
2nd Nov 2020 10:18pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2163 |
Darren Did your engine fire up after this simple job ? I’m broken down engine won’t fire up Keith |
6th Nov 2020 2:08pm |
Hi Keith,
Yes, it was absolutely fine. I believe that the engine should run without a MAF at all so unless you've got the wires crossed it shouldn't be a show stopper. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Nov 2020 2:10pm |
Yes your right Darren. But it’s now immobilised and just turning over. Completely baffled.
Thanks for the reply. Keith |
6th Nov 2020 2:16pm |
Thanks Darren
Sorted : https://www.defender2.net/forum/topic71100.html |
6th Nov 2020 3:38pm |
That's good news Darren
6th Nov 2020 10:27pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 345 |
Hey Darren - a quick question on paint: specifically what did you use on the ends of the one-piece rear half shafts and when you sprayed the HD drive flanges? I may have take inspiration from your ever excellent thread yet again...
17th Nov 2020 1:25am |
Hi MussEd,
The rears were primed and then given several coats of satin black. It was a Simoniz paint that I found in my local motor factors, which does appear to be harder than my usual go to of Halfords. The fronts were treated the same except that they were etch primed first due to the zinc passivate coating. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
17th Nov 2020 7:49am |
