Page 1295 of 1391 <123 ... 129412951296 ... 138913901391>
Tim300TDIMorts
United Kingdom 1997 Defender 90 300 Tdi SW Epsom Green
New steering wheel and optimill removable boss! Drives much better now!
Post #865575 5th Nov 2020 6:06pm
Jon TD5
2006 Defender 90 Td5 CSW Zermatt Silver
Looking good!!!
Very Happy
Post #865624 5th Nov 2020 10:07pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Washed yesterday, out in the fields today. Had to turn and snap a pic.
 Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #865743 6th Nov 2020 5:48pm
That just looks so purposeful... and right πŸ‘
Post #865749 6th Nov 2020 6:20pm
mcma1
Beaut Bow down Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #865768 6th Nov 2020 8:04pm
bodelafela
Australia
Started replacement of Shaft to a Ashcroft
Had a catastrophe failure a while back
Which was a shredded input shaft so thanks to some folks on here I got the Ashcroft unit
Started working on it today
Ended up disconnecting the transfer case unit to make room
Only tricky thing was trying lock the shaft in place to remove the big nut
Ended up using a rattle gun which worked a treat - just kept the gear in 1st
Then could not fit a puller into the casing so had to take the casing off
But it was a Censored to take off till I found a hodge. But under the 4WD gear stick
After that it came off easy and we were able to get the pulled into position
Tomorrow just got to re- Assemble everything back
Post #865817 7th Nov 2020 7:52am
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
That female coupling in the Ashcroft box looks like it's got the slots in it. Have they updated it or is it an earlier set.
Post #865976 7th Nov 2020 9:34pm
Mitch16
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
New to me 110
Evening all
I have just become the proud owner of this 110XS. 2013 model. Previous owner only did 15,000 miles and it was kept in a garage.
My first Defender and so far i love it. Hoping to get much more use out of it and keep it as standard as i can, although I would love to fit a roof rack if anyone has any recommendations.
Post #866177 8th Nov 2020 10:47pm
Mitch16
Photo now attached.
Post #866179 8th Nov 2020 10:49pm
Very nice. Not dissimilar to what my USW looked like when I bought it. Darren
Post #866181 8th Nov 2020 10:53pm
Tilly
United Kingdom 2010 Defender 110 Puma 2.4 USW Indus Silver
Inlet manifold off again today to try fix the leak. New seals fitted this time. The amount of oily carbon build up in the manifold is quite bad, ideally needs a good chemical bath to clean it all out but haven’t got time for that and assuming it is coming via the egr it will only build back up again. Scraped out what I could with the time I had today.
Post #866621 11th Nov 2020 12:13am
The oily gunk is likely to be coming from the crankcase breather via the turbo and intercooler, and is the reason why many of us have fitted Provent filters. The carbon is more likely to be coming via the EGR. Overall the toxic abrasive mix your engine breathes in these environmentally-aware days is not good for longevity!
Post #866712 11th Nov 2020 1:41pm
Tilly
The crankcase breather as you mention was noted on the last service as likely being restricted and in need of replacement. Looks like it needs doing sooner rather than later then. I will look into the provent filter you have mentioned. Thanks!
Post #866869 11th Nov 2020 11:43pm
CarMan
Changed the grill surround from body colour to black (like the black pack) - should I do the wheel arches next Question
Kept the original in case I didn't like it, or change my mind Rolling Eyes
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #867132 13th Nov 2020 6:32pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
I changed my front grill 4 times within the past 2 years... so definitely keep hold of the other set Embarassed
I personally wouldn't change the arches, I think changing the front end is fine as it's a 2 second job to swap it about... I'd be a bit more nervous about changing the arches with the same frequency... and then where does it end Laughing
Post #867137 13th Nov 2020 7:05pm
