Home > Puma (Tdci) > My manual for a DIY WEBASTO WATER HEATER on PUMA |
wrote right now..........
https://1drv.ms/b/s!AnHBx4Wc2MJLh0w1W5Rpcxh03xuM what do you think about my work? My Webasto still not installed yet.......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 22nd Jun 2016 11:28pm. Edited 2 times in total |
26th Dec 2010 2:05am |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2076 |
Hi Danielle
great stuff... I'll be refering to it when we get arround to fitting one later in the new year... Festive best wishes G&J (mind you - we could do with it this week as its minus 10 here at the moment!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
26th Dec 2010 10:23am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Looking good. Are you planning to use the webasto external temp sensor as well for full auto mode operation the same as the d3?
I would find this really useful as the puma actually cools down when used stationary or at low speeds in sub zero weather. Oh and how much to fit a system to mine !! Great work. Pom edited: iphone typing ftl. Last edited by pom on 26th Dec 2010 11:30am. Edited 1 time in total |
26th Dec 2010 10:43am |
I'm thinking to use the existing fuel tank adding the small metal pipe installed on the white Defender fuel tank plate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Dec 2010 10:49am |
if you install the temp sensor (it is a temp controlled switch, ON for temp under the 5°C and OFF when the temp rise up the 8°C) you can not switch on the heater when temp is 5°C or more. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Dec 2010 10:53am |
Hi Gary, Hi July Merry Christmas. hoping that y document will aid you..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Dec 2010 10:56am |
...........and, it is only the rev 0.0 of the document....
it will improved on the next days..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Dec 2010 10:58am |
mhmmm I think that the cost for the "travelling allowance" are too high...... I'm not competitive in UK may be I'm looking for a local company and sign a subcontract for UK operations..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Dec 2010 11:01am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
another master piece dg 2.4 90 XS
26th Dec 2010 11:27am |
au contraire! Sounds like a good excuse for a defender convey to the continent. Pom |
26th Dec 2010 11:31am |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
I'd be interested to see if there are any problems after you have been wading - particularly water getting into the exhaust system or problems with the electrics
26th Dec 2010 7:37pm |
Looking at fitting one with the winter fast approaching. Do you know at what coolent temp the webasto turns off ? Pom |
29th Aug 2011 8:40pm |
105°C inside heater chamber.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Aug 2011 10:34pm |
Thanks
29th Aug 2011 10:37pm |
