![]() | Home > Puma (Tdci) > Overheating in 6th gear going uphill (SOLVED) |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Have you tried replacing the cylinder head temperature sensor?
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835
As above - the CHT sensor will protect the engine from overheating by cutting the fuel supply momentarily giving the impression of a fuel problem and throwing no fault codes. Just because you're offended doesn't mean you're right.
| Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327
I came across that today in a post somewhere.
I'll do that one and see. I thought I saw someone say you needed a special tool to remove it? I did clean it off today as it had a film of oil on it - If its the one that sits at the back of the engine bay by the injectors that is |
From the Workshop manual.
"Cylinder Head Temperature (CHT) Sensor The CHT sensor is located at the centre rear of the cylinder head (transmission end). The sensor measures the temperature of the cylinder head and not the temperature of the coolant." |
| Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532
Replaced a few thermostats for sticking shut, causing it to overheat
Easy to test too |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
Does it need a special tool? Cheers
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
No special tool, but what I did was cut a slot in the socket which made it so much easier
On mine the temp needle would rise slightly when cold 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| Preston110 Member Since: 04 Nov 2020 Location: Sunderland Posts: 7
Exact same thing was happening to my defender 110. Was the coolant, crack somewhere in the system and it was leaking away and causing it to do the same thing.
How would you test to see if its working properly? |
I can't find any leaks in the system by looking but im not losing coolant unless I hit the 116 degree mark.
With the old coolant caps I could often hear them hissing after a run. |
Looking over the engine this morning, the radiator looks like it was replaced when the inter cooler was fitted by the previous owner.
When I unscrewed the coolant cap, the system is still pressurised from when I drove it yesterday. Is that a potential issue? |
| captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 357
Have you checked your EGR valves? 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
Egr was blanked off and removed when it went to have the maf and map done. It’s always been off but I had it done properly.
Could this be the issue....
After driving the car and getting up to temp I felt the radiator. It’s hot to warm across the top and cold everywhere else. What do we think? |
