Home > Technical > Galvanised Puma Doors?
rallysteve
Evening all,
Could you confirm if I am right in thinking that the later style of defender front and second row doors (i.e. the one piece pressed ones) are galvanised as supplied beneath the black primer?
Also, do the inner panels from the 02-05 doors fit without modification?
Thanks in advance,
Steve[/i] 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #860501 8th Oct 2020 6:51pm
dorsetsmith
I can say Yes for front inner panels from the 02-05 doors fit without modification
the only think door card 03 -04 do have to be modification
Post #860502 8th Oct 2020 6:56pm
rallysteve
Thanks Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #860503 8th Oct 2020 6:59pm
dailysleaze
They have a process applied called Zintec
"Zintec is designed to protect the mild steel during transport, storage, manufacturing and production processes"
Can't really compare it to hot dip but every little helps Laughing
Post #860510 8th Oct 2020 7:26pm
mk1collector
I still spotted corrosion on the door skin of our my15 dcpu a week or two ago so I have to try my hand at warranty on a 5 and a half year old defender Big Cry that should be fun! Ray
My build thread
Post #860511 8th Oct 2020 7:27pm
Wheel
Hopefully you're ok as body has a 6yr anti corrosion warranty but not sure if it has to have LR service or for them to do the annual corrosion/bodywork check.
Mines in next week for windscreen corrosion and that's a May 2015 model but I've only had it serviced at LR + also do extended warranty on it as I worry about getting caught out or suprised by LR big bills !!!!!
Gotta be worth a try either way tho !!!!!
Post #865313 4th Nov 2020 1:07am
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
I got my rear crossmember repainted under warranty when mine was 5 years and 9 months old . That was the second time they did it uner. Would be far easier and cheaper to put enough paint on in the first place. They wouldn't do the rusty front bumper because " that is a bolt on part " ! !
Post #865366 4th Nov 2020 3:14pm
Ianh
“Bolt on part “ , can’t see how they can defend that logic. The doors and just about every other part on a defender is bolt on !
Post #865377 4th Nov 2020 4:07pm
lakelander
Agreed but they wouldn't budge.
" bolt on parts " covers bumpers, rear and side steps, side tubes and mirror arms.
Pleased to get the crossmember and some bits around the windscreen corners done so just bought a galvanised black aftermarket bumper from Craddock and fitted it myself.
Post #865397 4th Nov 2020 6:24pm
