![]() | Home > Maintenance & Modifications > sump guard |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8483
do you mean a combined steering and sump guard? not sure i know of any or even know of any dedicated sump guards. plenty of steering guards out there and likewise various different front axle guards out there too. Cheers
| the shepherd Member Since: 27 Sep 2016 Location: surrey Posts: 18
I have a diff guard but now need a steering guard probably not the sump....
Quite a few out there. Some offer good protection, some offer great ploughs, and some look good.
4 chassis mounting points, room for recovery rings on chassis, 3 piece assembly, tabs to pick up on steering damper mount(unused one on drivers side) reinforcing on rear of main guard would all be my search criteria. Or, bolt/weld a protective loop on the chassis in front of the steering box shaft and fit hd sumo bars from Gwyn Lewis. Also consider boxing in track rod if you drive in areas with stumps/brash or rocks. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
thanks I will follow up your suggestions
