Home > Puma (Tdci) > Lowering 90
Crunchie
Ireland
Lowering 90
If I lower my 90 with a set of springs/shocks/arb , Do I need to check prop angles or anything else under the car after install?
Post #864363 30th Oct 2020 7:01am
Co1
Depends how low you go. Normally it’s -2” and you done need to do anything else, but it will obviously affect articulation and off road ability.
Post #864365 30th Oct 2020 7:08am
Dinnu
For my older 90, I always wanted approx 1" lower at the back only. I almost always drove it unladed.
My newer acquisition had a 1" lift at the front only, and I really like how level it sits.
I think I will still go for the 1" lower at the back only once the restoration is complete. Makes it easier for me getting in and out
of it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #864375 30th Oct 2020 9:09am
Mine is -1” with 265/75’s
 QRZ M8VPF
Post #864378 30th Oct 2020 9:36am
This is probably better, parked on flat ground.
No change to props.. (the rear is custom length though due to the gearbox being longer)
I also lowered Mrs G’s
 QRZ M8VPF
Post #864380 30th Oct 2020 9:40am
Tonser
Thanks for uploading these pics Greeni, really helpful. I'm looking at 1" lower for mine. Just wondering which springs to go for Question
Tony
Post #865843 7th Nov 2020 10:19am
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Love them both, is Mrs G's also a 1" drop?
Post #865957 7th Nov 2020 7:57pm
Yeah both were. Eibach comfort springs.
The V8 is now also on FOX 2.0 dampers. QRZ M8VPF
Post #865958 7th Nov 2020 7:59pm
Moneypit
Thanks, I'm convinced, time to order some new springs
Post #865962 7th Nov 2020 8:04pm
