Home > Maintenance & Modifications > Routing internal dab aerial wire
peanutbob
Ref the dab wire, I am going to route the down the left plastic interior a pillar and then across the lower windscreen to the centre of the dash...the connector is circa 1.5 cm wide. Is it possible to feed this down behind the dash centre to connect with the radio? Is there room before I start fiddling around!?
Thanks.
Btw vehicle is a 13 plate puma.
Post #863271 23rd Oct 2020 8:50pm
Probably just, if you need a tiny bit of extra room just take a couple of dash fixings out move away just a little bit. Install and then replace. The small amount of room your looking for this would be possible.
If you need extra room in A pillar trims, mid do good ones, but unless you have lots c of wiring up and down there like I do I doubt you’ll need them unless the wire dia is significantly large saw 4mm +
Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #863283 23rd Oct 2020 10:08pm
peanutbob
Excellent thanks. The wire dia is quite thin so the existing trim should be ok, though there is a large wire already routed thru ...not too sure what it feeds maybe the rear light and rear heated screen perhaps but all should be ok.
Post #863289 23rd Oct 2020 10:34pm
jimbo55
You shouldn’t have a problem routing it there, I have a cb radio cable and spot light cables outed that way on mine and it is tight but it does all fit without issues
Post #863303 24th Oct 2020 6:59am
hank
Rather than routing across the lower windscreen to the centre of the dash remove the top dash cover over the passenger stowage shelf thing (two screws to remove), then you can route the cable into this void at the base of the a pillar cover. Inside there are large openings to the rear of the head unit > 110 XS Double Cab
Post #863330 24th Oct 2020 1:08pm
peanutbob
That is very useful information! Many thanks. It’s a job for tomorrow morning as today’s deluge has subsided.
Post #863372 24th Oct 2020 6:52pm
peanutbob
Job done ...excellent tip! Thanks!
Post #863456 25th Oct 2020 11:26am
hank
Post #863460 25th Oct 2020 11:57am
