![]() | Home > Maintenance & Modifications > Routing internal dab aerial wire |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Probably just, if you need a tiny bit of extra room just take a couple of dash fixings out move away just a little bit. Install and then replace. The small amount of room your looking for this would be possible.
If you need extra room in A pillar trims, mid do good ones, but unless you have lots c of wiring up and down there like I do I doubt you’ll need them unless the wire dia is significantly large saw 4mm + ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 352
Excellent thanks. The wire dia is quite thin so the existing trim should be ok, though there is a large wire already routed thru ...not too sure what it feeds maybe the rear light and rear heated screen perhaps but all should be ok.
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408
You shouldn’t have a problem routing it there, I have a cb radio cable and spot light cables outed that way on mine and it is tight but it does all fit without issues
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Rather than routing across the lower windscreen to the centre of the dash remove the top dash cover over the passenger stowage shelf thing (two screws to remove), then you can route the cable into this void at the base of the a pillar cover. Inside there are large openings to the rear of the head unit > 110 XS Double Cab
That is very useful information! Many thanks. It’s a job for tomorrow morning as today’s deluge has subsided.
Job done ...excellent tip! Thanks! |
| All times are GMT |
