Home > Puma (Tdci) > LOF MT82 Upgraded Adapter Shaft |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I tend to agree with Blackwolf, there is some unknown variable in the way these things have been manufactured and assembled. It would be interesting to pull a complete assembled gearbox/transfer box whole that has failed and see if the mounting face of the bell housing is perfectly parallel with the transfer case output flanges. If not that would at least confirm something was out of alignment in between. 2007 110 TDCi Station Wagon XS
8th Sep 2020 9:41am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1351 |
The miss alignment probably comes from an accumulation of tolerances, this might help to illustrate. Angles and offsets exaggerated to show possible effects, https://www.defender2.net/forum/topic62521-135.html |
8th Sep 2020 12:30pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3207 |
My 2012 90 has a history of eating through adapter shafts. I think 4 in all in just over 110kmiles.
Recently needed to take the transfer box out because of an oil leak (Ashcroft adapter shaft aluminium cover was badly fitted and leaked there). Knowing the history, I tried to see what could be the cause. With the limited tooling I have, I checked the planarity of the adapter housing faces, and they were within 0.10mm (100 microns or less than 4 thousands of an inch). All dowel pins had a good fit. I could not get relative position measurements between dowel holes on one side to the other side of the adapter plate. What I also noted, the Ashcroft adapter shaft had absolutely no wear in the usual splines. Unfortunately, however, mine suffered some wear on the gearbox mainshaft (https://www.defender2.net/forum/topic59735-240.html). Possibly the 'flow' of oil from the main gearbox to the kerb side helped to preserve the usual adapter splines 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Sep 2020 4:37pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Excellent, thanks DSC Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
9th Sep 2020 11:35am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 906 |
LOF shaft fitted yesterday.
Really straightforward install get it all in and that's one problem area dealt with. and i did the clutch whilst i was in there too Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
4th Oct 2020 11:46am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 421 |
I'd even go one step beyond : LR planned the 2 splines because there really exist fab tolerances. Otherwise it could have been just 1 single part + 1 spline (like LOF suggest it to be). You can find this sort of splines in almost any agricultural vehicle and tolerances are even worse. And any technician can explain what would happen if these splines moved without lubrication ... |
7th Oct 2020 10:17pm |
Perhaps LOF want to mitigate the LT77 and R380 where the mainshaft is one piece going into the transfer box. But for both LT77 and R380, the transfer box bolts on directly to the gearbox without adaptor housings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
8th Oct 2020 8:42am |
pedrocandrade Member Since: 30 Sep 2022 Location: Rio de Janeiro Posts: 26 |
Hello everyone. I'm just wondering if we have news on the durability of LOF's solution here. I'm thinking of buying one for my 2011 Puma as it will soon get a new clutch from LOF as well.
Thanks! |
2nd Mar 2024 12:27am |
25 odd thousand miles later and AFAICT it is just as sound as the day it went in. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
2nd Mar 2024 4:54pm |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 714 |
only 12K miles on mine, but shaft and clutch have been great
2nd Mar 2024 8:36pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 955 |
I too had the LOF shaft fitted last year, my local LR specialist says a much better upgrade than OE Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
2nd Mar 2024 9:06pm |
