![]() | Home > Puma (Tdci) > Confirmation of correct central locking loom by photo/PN? |
| Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 |
EDIT: The seller has just been good enough to come back to me and to confirm that these were bought from BoltOnBits, they are unused and that they were described as:
'Door Wiring Electric Window Central locking harness & gaiter Defender 2002-2016" and "Left Door Wiring Electric Window Central locking harness Loom Defender 2002-2016". When I've looked these up on the BoltOnBits shop they do say that they are genuine parts. So - it seems they're the right bits. But if you;re reading this then I would welcome some confirmation that the plan above will indeed let me fit "genuine" remote central locking to the vehicle. Course the other question is whether its worth fitting electric windows while I'm at it - more cost but if I save time then it may be worth considering, only my understanding is that while the central locking is a plug-in job from a wiring perspective (albeit needing a re-done ECU) but the central locking would require wiring to be done behind the dash which I'm a bit nervous about. Thank you again! |
| trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405
Have you checked in the door pillar that you don’t actually have the correct wiring for the electric windows already installed.
I have a basic spec 2014 model and surprise surprise I found the central locking wiring and the electric window wiring tucked away in the door pillar. I took off the electric window switch blanks and the wiring blocks were there ready to accept the switches. Landrover has a habit of doing this, rather than putting in different wiring or looms, they just fit them and hide them away. If that is the case you would only need the regulators and switches. Installing both is not a particularly difficult or time consuming job. I gave Robin in the parts dept at Duckworth Landrover a call and he put the whole shopping list together. For me. |
I’d seen your posts and was very encouraged.
But... embarrassment time. I hadn’t actually checked the door pillar. Just been out and looked - including with a cheap endoscope... no wires at all. Only the purple one for the door switch. So unless the door connectors are Actually tucked back through the pillar Behind the lower speakers and under the dash I think I’m out of luck - I seem to be missing this leg of the loom altogether! Not what I was expecting to find: gutted. |
| shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551
I've literally came from microcat to ask the same question lol. I want to install central locking and electric windows in my doors but have part numbers for looms going from €40 - €140 euro. If i find out anything i'll update you
Have you pulled off the window switch blanks, that would give you an indication of whether the looms have been fitted.
If they haven’t then I suggest a look at mobilecentre.co.uk where you will find various options that will solve the problem of the electric window issue. Or you could look for the aftermarket kits that are available from various suppliers then that would leave just the central locking part of the problem to resolve. |
| Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68
I fitted central locking to mine and since it was basic spec I didn't have any of the xs central loom, You will need part of the central loom already installed in addition to the parts you have mentioned. If you don't already have the central loom I would advise speaking to Dan Padmore at PACE Automotive, He has his own uprated looms that he makes and will be able to advise you best.
| Francisco Member Since: 25 Sep 2020 Location: Parana Posts: 11
Hello
I'm new here and I'm a little lost. This topic talks about a subject that brought me a doubt. The actuator of the electric lock FUD500020 must be fixed in some way and that is my doubt. How the actuator is fixed / screwed to the door. Is there any specific support? What is the support code? |
| All times are GMT |
