![]() | Home > General & Technical (L663) > 2020 modifications |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Interesting to read that Adblu is actually still with us because car makers colluded.
EU fines VW and BMW £750m for colluding with Daimler on fumes "The EU has fined Volkswagen and BMW €875m (£750m) after finding that the German carmakers colluded with another rival, the Mercedes-Benz owner Daimler, to delay emissions-cleaning technology. The European Commission said that the carmakers had “breached EU antitrust rules by colluding on technical development in the area of nitrogen oxide cleaning”. Volkswagen, the world’s largest manufacturer of cars, will pay €502m, a reduction of more than half the original fine because it cooperated with the investigation. BMW will pay €372m, far lower than the provision for well over €1bn that it had initially made. Daimler escaped without a fine because it had revealed the cartel to the commission. The commission’s latest announcement said that the carmakers had also worked together over a period of five years to delay more efficient technology to remove nitrogen oxides by adding urea (a chemical found in mammals’ urine that is sold as “AdBlue”) to exhaust gases. While the process dramatically lowers diesel emissions, it lowers the performance of the engines. Daimler, BMW and Volkswagen, plus VW’s Audi and Porsche brands, exchanged information on AdBlue tank sizes, meaning they did not have to worry about competing with each other on having cleaner engines, the commission said. Margrethe Vestager, the commission’s powerful executive vice-president in charge of competition policy, said: “The five car manufacturers Daimler, BMW, Volkswagen, Audi and Porsche possessed the technology to reduce harmful emissions beyond what was legally required under EU emission standards." https://www.theguardian.com/environment/20...r-on-fumes ![]() Last edited by Supacat on 9th Jul 2021 4:16pm. Edited 1 time in total |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Saw this on FB, what a mint installation!
https://www.facebook.com/groups/6862732818...713598715/ "12v setup including a lithium battery with a redarc 2000 inverter. Redvision along with the switchpros in the sunglasses panel means I can use either to control most of the devices. Can also jump start the vehicle from the 2nd battery also. Lots of charging points, including the ability to put in the solar from the roof rack. Dashcam install was clean. Most of the wiring was done via the back right and through the factory grommets. GME UHF and Redarc TowPro install in clean locations also. Happy with the results. Both light bars can be switched between a high and low setting depending on what I'm using it for. Custom fabrication to hold the 12v panel was made by making a mould of one of the existing compartments to make it look the same. Only difference is swapping the existing temp control knob to a bit lower! Table mounted to the door also for cooking etc. Used existing floor also." -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| All times are GMT |
