Home > Maintenance & Modifications > Leisure Battery fitted to SSE Utility
Page 2 of 2 <12
dorsetsmith
have two main connector one main starting battery and the other one sec battery and small one going ground i.e. battery ( - )
that look too low more like 13.78v too 12. 68 v
check that large fuse haven't been re moved from two large cable (if fitted) and also ground wire is in place between unit and battery ( - ) or body work
halls electrical ltd Bristol, Swindon , Exeter suppled the unit
Post #857425 22nd Sep 2020 2:44pm
Liam Murphy
United Kingdom 2009 Defender 110 2.5 TD HT Tamar Blue
Thanks for all the info and the manufacturer, much appreciated.
Is this the main fuse you referenced?
There's a definite break in volts in between these two points. One side is reading over 12v whilst the other side of it is reading 0.6v so I suspect this is the issue.
If I can't find a replacement I'll try contacting the manufacturer
Post #857465 22nd Sep 2020 6:00pm
Bluest
That fuse looks like one of these https://www.arc-components.com/0-378-33-vi...-1849.html 2007 110 TDCi Station Wagon XS
Post #857468 22nd Sep 2020 6:12pm
Liam Murphy
That's exactly what it looks like! Thanks!
I've just taken the 200 fuse off and the voltmeter is reading a flat 0, which suggests it's all good inside, right?
I'll get a spare on order anyway
Post #857471 22nd Sep 2020 6:28pm
jst
Join the wires on one of the studs, what do you get from outputnofnspkit charge then. It probably needs the main battery over a set voltage 13.6? Before it will switch over anyway. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #857473 22nd Sep 2020 7:04pm
MichaelE
Joe the Plumber wrote:
Absorbed Glass Matting. I'd give it another go if I were you. There's stacks of very sensible information on there.
Thank you
Post #857537 23rd Sep 2020 5:24am
Page 2 of 2 <12
