Home > Maintenance & Modifications > Air con grill on non air con Puma..
Page 2 of 2 <12
NickMSM
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
So I thought I would test fit everything today before paint, and the air con surround doesn't seem to fit. The holes don't align where it screws into the slam panel - they are too far forward and the grille if anything seems a little wide too?! Am I being stupid or are there different versions?
Post #855500 11th Sep 2020 4:36pm
mk1collector
The recessed part on the side of the grille should slide in between the two wings. You could add a washer to either side of the slam panel to push the wings out a little or try just to push the grille panel in at the side. If genuine it’s only made of fibreglass so will usually flex a little, and as you push will pop in between the two wings. Ray
My build thread
Post #855513 11th Sep 2020 5:53pm
There aren't different versions of the grill panel but there probably are of the of the slam panel. As Ray says though, nothing that can't be resolved with a bit if packing and ingenuity. Darren
Post #855615 12th Sep 2020 10:05am
NickMSM
Thanks - I've got it on, but can't for the life of me get the far left screw holes to line up with the slam panel. Seems to be catching at the very top of the surround where it meets the wing. Will have another look but might have to trim it slightly Confused
On another note, what are the bolts needed to attach it on the sides to the bracket? One on each side towards the bottom of the surround.
Post #855663 12th Sep 2020 4:49pm
They are actually very large screws, no.14 x 3/4", that screw into spire nuts clipped on the end of the brackets. The part number for them is AB614065L.
https://www.lrworkshop.com/parts/AB614065L Darren
Post #855665 12th Sep 2020 4:58pm
NickMSM
Brilliant, thanks Thumbs Up
Post #855676 12th Sep 2020 6:29pm
Page 2 of 2 <12
